Fuel Pump Compatability?
Old Jun 28, 2012 | 04:16 PM
SiscoKid's Avatar
SiscoKid
Question Fuel Pump Compatability?
I have 2 F-150's. Both are equiped with 300 6cyl engines, 5 speed manual transmissions. One of them is an 89 that is 4x4, and the other is a 95 2 wheel drive. I would rather keep the 89, so i am taking some parts out of the 95 when i can. Does anyone know if the fuel pump out of the rear tank will be compatable with the same of the 89?
Old Jun 28, 2012 | 05:54 PM
rla2005's Avatar
rla2005
No, the '89 uses a low pressure in-tank fuel pump whereas the '95 uses a high pressure in-tank fuel pump. Ford switch to a different fuel system in 1990 IIRC.
Old Jun 28, 2012 | 06:22 PM
kd0axs's Avatar
kd0axs
Correct. The older ones have a low pressure pump in each tank, which pump the fuel out to a high pressure pump on the frame rail. The 95 has a high pressure pump in each tank.
Old Jun 28, 2012 | 09:02 PM
SiscoKid's Avatar
SiscoKid
Thanks for the quick response guys! This will save me alot of work. This forum is the ****!
Old Jun 28, 2012 | 09:41 PM
White 97 xlt's Avatar
White 97 xlt
Sorry to hear that!!
gthbryce
Oct 30, 2009 07:30 AM
skylarkman
1978 - 1996 Big Bronco
Dec 22, 2008 02:52 AM
Chumbucket
Mar 31, 2004 05:02 PM
Jimmy Dean
Mar 19, 2004 07:40 PM
JARHEAD8387
Jul 5, 2003 02:38 PM
