Sponsored by: Real Truck
Rear door stuck
Old Jun 28, 2012 | 03:20 PM
Keepitrunnin's Avatar
Keepitrunnin
Rear door stuck
2001 F250 extended cab. Rear suicide door won't open. seems the top latch is not releasing. I need to get it open to fix, but can't seem to open it. Any suggestions will be appreciated.
Old Jun 28, 2012 | 04:07 PM
Flyinstroke's Avatar
Flyinstroke
that happened to my old truck once and i had to pull the inside door panel off to get to the cable that came loose. I also pulled the rear seat because it was a PITA to get the door panel off. Once you get that off you can see what you are dealing with. Should be pretty easy to locate the problem.
flht
Feb 12, 2014 05:54 PM
JR Truck
2004 - 2008 F150
Nov 27, 2013 06:19 PM
SunBum
Apr 1, 2013 01:34 PM
pin8246
Jan 6, 2013 09:52 PM
tfarms
1997 - 2003 F150
May 11, 2009 05:55 AM
