360 base timing
Old Jun 28, 2012 | 12:38 PM
nobearsyet's Avatar
nobearsyet
360 base timing
I picked up another 68 f100 the other day, 360 and a 3 speed on the floor, 9" with 3.50 gears. Plan is to make it a really tame little daily driver, I put an Edelbrock Performer and a 600cfm Holley 1850-2 (4160 type carb with vaccuum secondaries) that has a .110 needle and seat. Quickfuel "4 door" power valve, and clear sight glass plugs. Question I have is what is my base timing supposed to be? Otherwise except for a set of glass packs and 2.5" pipes this engine is stock.
Old Jun 28, 2012 | 12:50 PM
willowbilly3's Avatar
willowbilly3
I's start around 8 and listen for ping. Bump it up a couple degrees at a time until you hear slight ping on full throttle, then back it down a couple degrees. Factory specs are just a guide line any more since fuel was way different back then that it is now.
jlaudio_f100
26
May 19, 2011 11:27 PM
Nod
Dec 31, 2010 09:15 AM
Pinewoodburner
Jan 6, 2009 10:11 AM
MAHinton
May 9, 2004 09:00 PM
kelsey
Sep 26, 2002 07:01 PM
