Timing vs. economy
Old May 8, 2004 | 11:36 PM
MAHinton's Avatar
MAHinton
Timing vs. economy
In the FAQ, it is suggested running the timing at 10 to 12 BTDC for improved throttle response instead of the factory/stock 6 BTDC. How will this affect fuel economy? Also, set around 6 (not sure) BTDC, I get some popping through the carb when I change from acceleration/steady to coasting (ie coming down a hill, taking foot off gas to slow down for speed change). I know this can be cured with timing, but which way?
Engine is a 390, 2bbl, stock except bored +0.030
Thanks for the help.
Matt
Last edited by MAHinton; May 8, 2004 at 11:38 PM. Reason: Forgot to include engine specs
Old May 8, 2004 | 11:41 PM
fordeverpower's Avatar
fordeverpower
i'm not sure on the popping but more degrees is more economy. I had some problems with to much total timing. You might want to check that. You don't want more than 38 degrees.
Old May 9, 2004 | 01:12 AM
mlf72f250's Avatar
mlf72f250
Within reason, it should give you better fuel economy. 10-12 sounds reasonable to me.
If you take it too far, you'd probably reach the point of diminishing returns. Or of course start the engine knocking. But, even if you put aviation gasoline in it... Advancing beyond that, it's possible the economy could get worse, but I'd guess you'd have to take it pretty far.
Old May 9, 2004 | 09:36 AM
MAHinton's Avatar
MAHinton
By "too much total timing", I'm assuming you are adding the vacuum advance to the timing of 10-12 BTDC, correct? How do I check that to see how much the advance changes the timing? I have the stock/replacement breakerless ignition system (replaced at O'Reilly's when I did the engine 8 years ago), nothing upgraded or replaced on it except cap, rotor, and wires when needed.
Also, engine was originally a 360 until the rebuild. The original sticker is still on the valve cover. According to that, plug gap should be between 0.052 and 0.056, so I have also gone with 0.054. Anyone I tell this to is shocked at the huge gap. In my Haynes manual, it calls for 0.044 gap. How much difference will the gap make in power/mileage/life of plugs/coil/wires?
Thanks again...
Matt
Old May 9, 2004 | 01:43 PM
scroob's Avatar
scroob
Run as much timing as you can get away with without detonation. As far as economy, one has to balance the price of higher octane gas these days against any gain you might get from advancing the timing to the point where you need it. 92 octane is $2.59 in my area.
There is a limit to how much you can advance the timing no matter what fuel you're using.
As far as plug gap, around .045 is what I have always seen for electronic ignition. So the .044 sounds correct.
Old May 9, 2004 | 06:21 PM
fordeverpower
well after I switched over from a 2bbl to 4bbl on my 390 there was 55 total degrees and that had caused the carb to pop and backfire at times. I had to much total timing since I had bought the truck. A way to check it is to mark the balancer at 38 degrees but it only goes to 30. Guesstimation time. Then check the timing with the vac advance hooked up and apply the throttle. Watch to see where about it maxes out at.
Old May 9, 2004 | 09:00 PM
mlf72f250's Avatar
mlf72f250
Thanks again...
Matt
It's tough to put any hard number on it, but as your wires/cap/coil get older and dirtier, they will likely start to have arcing during more humid times. The spark takes the path of least resistance. If your gap becomes too big, the path of least resistance may be somewhere other than the spark plug gap. So you get a spark from the wire to the valvecover (or something like that) and no spark at the plug. If the gap is smaller, that may be the easier path, keeping the engine running fine. The wide gap could particularly cause problems at high liad when the cylinder pressures are higher.
Of course, there is always the opposite argument... A larger gap will enable you to run well with leaner mixtures withouog misfire. The greater gap gives you a bigger spark volume, creating a higher probability of good ignition under marginal conditions. BUT, when the automakers do this, they use fatter plug wires, and better designs and materials for the rest of the system to handle it.
matt.likes
20
Mar 25, 2014 02:52 PM
nlareau
Nov 15, 2011 10:50 AM
Drac
Feb 1, 2008 10:19 AM
switzee
Bronco II
47
Jun 17, 2005 06:15 PM
micah
Dec 22, 1999 05:46 PM
