Torque App Accuracy?
Old Dec 2, 2012 | 07:10 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Originally Posted by surfmanrescue
Amdriven:
Thanks for posting so much info...Have you checked the TFT readings from the torque app against the scangauge? I was getting TFT readings of 186 to 190 with the Torque when the OBD header was blank...Changed it to TCM and now I am getting about 150 when it is good and warmed up (city/no tow)...Question is, which one is correct? Concern is, are we just changing parameters to get the numbers we want...
Also, does any one know what changing the OBD header from Auto/HEX/TCM is actually doing?
I don't know if I missed it, I have read so much, what is the current formula for ECT (for Torque app)?
Since the temp is coming from the Tranny, it just needs to be reading from the right area of the system.
As for the temps, see what they read, ECT-EOT-TFT, in the morning after a cold soak.
I realized the original temp readings were wrong when the Tranny was always the same as ECT. Doesn't happen! The Torque developer found it needed to come from the TCM So, no, we are not just changing things to get a different reading.
Also, these trannies do run cold. The hottest I have seen my trans temp was when towing 8000+ in the summer up a very long grade in Central Oregon. It got to 180. Now, these readings do compare with the SGII.
I have compared SGII with the Torque APP for many of the gauges, and they match quite well.
Old Dec 2, 2012 | 07:16 PM
surfmanrescue's Avatar
surfmanrescue
Thanks for such a thorough response...yeah I wondered why my ect was the same as my tft.
JESTERxHEAD
Aug 5, 2025 06:45 AM
75 F100 4X4
Aug 20, 2017 02:40 PM
Crewcab Turbo
Feb 9, 2015 10:57 AM
powells_f150
2004 - 2008 F150
Jun 30, 2014 05:52 PM
f350ranchand
Jul 24, 2013 01:15 PM
