Torque App Accuracy?
i couldn't see with my edge insight.FMP
PID: 2209D0
Unit: Volts
Max/Min: 50/0
Equation: ((A*256)+B)*(100/256)/100
FICM Logic Power
FLP
PID: 2209CF
Unit: Volts
Max/Min: 50/0
FICM Vehicle Power
FVP
PID: 2209CE
Unit: Volts
Max/Min: 50/0
Fan Speed Sensor
FAN
PID: 22099F
Unit: RPM
Max/Min: 1000/0
Equation: ((A*256)+B)*(1/4)
Injection Control Pressure
HPOP
PID: 221446
Unit: PSI
Max/Min: 5000/0
Equation: ((A*256)+B)*(57/100)
Fuel Pump Duty Cycle
FPDC
PID: 221672
Unit: %
Max/Min: 100/0
Equation: A*100/128
Torque into Torque Converter
TC TQ
PID: 2209CB
Unit: Lb-Ft
Max/Min: 1000/0
Equation: ((A*256)+B)*(1/1)
Engine Oil Temp
EOT
PID: 221310
Unit: Deg. F
Max/Min: 300/0
Equation: ((((A*256)+B)/100)-40)*(9/5)+32
VGT Duty Cycle
VGT
PID: 22096D
Max/Min: 100/0
((A*256)+B)*(100/32767)
FUEL LEVEL
FUEL
PID: 2216C1
Max/Min: 100/0
((A*256)+B)*(100/328)
Volume Fuel Desired
221411
VFD
0.0
50.0
x.1
GPH (gallons per hour)
((((((A*256)+B)*(100/16)/10)*8)*3600)*3785411.78)
AUTO
CYL #1 Cumulative Misfires
22160E
1CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #2 Cumulative Misfires
22160F
2CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #3 Cumulative Misfires
221610
3CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #4 Cumulative Misfires
221611
4CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #5 Cumulative Misfires
221612
5CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #6 Cumulative Misfires
221613
6CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #7 Cumulative Misfires
221614
7CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #8 Cumulative Misfires
221615
8CM
0.0
100.
X1
MISFIRES
((A*256)+B)
Injection Pressure Regulator Duty Cycle
221434
IPR
0.0
100.0
x1
(A*13.53)/35
AUTO
Injection Timing BTDC
2209CC
INJ
-50.0
50.0
X1
DEG.
((A*256)+B)*(10/64))/10
AUTO
Battery Voltage
VBatt
221172
0.
16.0
(A/16)
AUTO <!-- / message -->
If you scroll down through this page of a thread on the torque app forums, you will see some of the conversation about it. Also on a previous page in that thread also.
Forums — » Torque OBD ECU Scanner » Torque Discussion / Ideas » Ford 6.0L Diesel Extended PIDSTorque
Will BITE, does the above equation work for your EOT?
Go to edit the Trans temp like you did for EOT. Make sure to change from "auto" to "TCM".
Then when you add a gauge, pick "Trans FL" temp, which should be the first trans gauge to select. Not the "method 1 & 2"
PID = 221674
Short name= TransFl
Min= 0.0
Max= 300.0
Scale= x1
Unit= F
equation= ( ( A * 256 ) + B ) / 8
OBD header to use= tcm
That will
Any help will be awesome
On phone:
Open settings.
Tap wireless and networks, or Bluetooth.
Tap search for devices if adaptor isn't already recognized.
Select OBDII device once recognized.
Long press device name, and select pair.
Open Torque and watch for connection.
If no connection, unplug adaptor for 30 seconds, and plug back in.
Yours might have a slightly different process, but this gets you really close to where you can hopefully figure it out.
PID = 221674
Short name= TransFl
Min= 0.0
Max= 300.0
Scale= x1
Unit= F
That will
Thanks for posting so much info...Have you checked the TFT readings from the torque app against the scangauge? I was getting TFT readings of 186 to 190 with the Torque when the OBD header was blank...Changed it to TCM and now I am getting about 150 when it is good and warmed up (city/no tow)...Question is, which one is correct? Concern is, are we just changing parameters to get the numbers we want...
Also, does any one know what changing the OBD header from Auto/HEX/TCM is actually doing?
I don't know if I missed it, I have read so much, what is the current formula for ECT (for Torque app)?
