No start, then started
Old Dec 2, 2012 | 03:45 PM
tjustice's Avatar
tjustice
Ok, well I drove the truck off and on all day,parked it for couple hours with the nose headed down a slight hill. Come out to go home, truck cranks no start. SG2 says 275 om ICP, so pull wires of truck starts just fine. Plug ICP up come home cut the truck off and starts like a dream....
Any ideas????
Old Dec 2, 2012 | 03:48 PM
Rusty Axlerod's Avatar
Rusty Axlerod
By pulling wires you mean unplugged ICP sensor? If so, was the connector oily?
Old Dec 2, 2012 | 03:50 PM
tjustice's Avatar
tjustice
Sorry brain out ran fingers. Yes unplugged the ICP.. No was dry, I just replaced it about a month ago.
Old Dec 2, 2012 | 03:53 PM
BLADE35's Avatar
BLADE35
Plug ICP sensor back in
then post
ICPV at KOEO
Old Dec 2, 2012 | 03:54 PM
Rusty Axlerod
That would worry me a little. Maybe you could park nose way down at home to check it. At least you wouldn't be stranded "somewhere". I guess it's also possible the ICP connector wasn't making a good connection and un plugging and plugging it back in helped.
Old Dec 2, 2012 | 04:01 PM
BLADE35's Avatar
BLADE35
I think he has a HPO Leak Eric
Better do the Full Deal for HPO Diagnostic
OPERATING VALUES
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
A/C OFF
#1-------KOEO=Key On Engine Off =record EACH sensor value and POST IT!!
#2-------Low Idel (truck idel on its own)=record EACH sensor value and POST IT!!
#3-------High Idel (2500RPM)=record EACH sensor value and POST IT!!
Do this for
ICP
ICPV
IPR%
Old Dec 2, 2012 | 04:06 PM
tjustice's Avatar
tjustice
[quote=BLADE35;12550514]Plug ICP sensor back in
then post
ICPV at KOEO = .25
Running = .85 at idle
Old Dec 2, 2012 | 04:15 PM
BLADE35's Avatar
BLADE35
[quote=tjustice;12550555]
then post
ICPV at KOEO = .25
So from those Numbers the ICP Sensor is Good
What happens when you unplug ICP Sensor and get it to start is the PCM Will use a Default ICP value.
So in your case I suspect the ICP Default value will turn on FICM and Fire injectors
Probably a Really small Leak or weak HPOP
Now Post IPR% at Idel if its any Higher thasn say 30% at Idel you have a Problem/Leak
Old Dec 2, 2012 | 04:17 PM
BLADE35's Avatar
BLADE35
Or Like Rusty says ICP Plug was dirty and Not getting good contact
Post IPR% at Idel then we should know whats going on Better
Old Dec 2, 2012 | 04:24 PM
tjustice's Avatar
tjustice
IPR = 22.66%
Old Dec 2, 2012 | 04:30 PM
Rusty Axlerod
10-4. I guess cranking up with ICP disconnect threw me off HPO leak. I think he was thinking of Marks post about the HPO resivour draining down.
Old Dec 2, 2012 | 04:33 PM
BLADE35's Avatar
BLADE35
Was that ICP plugged in???when IPR% taken ????
I take it your HPO System bleeds off after sitting awhile
Old Dec 2, 2012 | 04:38 PM
tjustice's Avatar
tjustice
Yes it was plugged in.
I work 24 hour shifts, it sets for probably 26 hours every other day and has fired right up. First time it has done this..Getting ready to post pic of numbers.
Old Dec 2, 2012 | 04:40 PM
tjustice's Avatar
tjustice
Old Dec 2, 2012 | 05:09 PM
tjustice's Avatar
tjustice
