Neutral safety switch?
Old Jun 26, 2012 | 10:05 AM
taylornelms's Avatar
taylornelms
Finally got a random day off and decided to do a little needed tlc on my truck. 2000 f250 cc 4x4 with 200k miles auto.
A little over a moth ago I had a jasper tranny installed by a shop. Since that time I have had issues with my truck not starting... The ignition has been replaced, we thought t could have been that because the cylinder was a little worn out. It would start in neutral but not park. Sometimes it would act normal and start right up other times it would t do a thing!
The new cylinder didn't do anything but waste 225$ of my money.
Another related issue is my back up lights, they worked fine before the trans install now they don't work at all, which leads me to believe there is something in my truck that is not recognizing what gear I'm in..
Is there a plug in on the trans that maybe didn't get plugged in???
Sorry for the book but any help ASAP would e great I don't get many days to work on my truck...
Old Jun 26, 2012 | 10:21 AM
mueckster's Avatar
mueckster
The DTR (digital trans range) sensor probably needs adjusting. You can loosen the two bolts and turn it slightly. Tighten to 7 ft-lbs.
Name:  DTR Sensor.gif
Old Jun 26, 2012 | 10:38 AM
taylornelms
Thanks I'll give it a try
Old Jun 26, 2012 | 11:51 AM
fordpride's Avatar
fordpride
There is two line up marks on it. One on the body and one on the white center around the shaft. Loosing the two bolts and line up the marks.
Old Jun 26, 2012 | 01:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They line up in Neutral. Make sure the parking brake is on AND the wheels are chocked!!!
Old Jun 26, 2012 | 03:15 PM
fordpride's Avatar
fordpride
Yea I forgot about that part. Thanks mark.
Old Jun 26, 2012 | 11:35 PM
GonzoCSU's Avatar
GonzoCSU
Did you check the bolts on the shift cable under the dash? I know that will cause the no start in park issue and also not being able to get into 1st gear, not sure about the reverse lights though.
I suffered through shifting into neutral to start my truck for a year before I saw someone on the forums post about the two bolts under the dash. One was so loose I am surprised it hadn't fallen out yet.
Tyler_m
May 18, 2018 12:04 AM
FordIowan
Nov 11, 2014 08:33 AM
cdc120
Sep 9, 2013 05:36 PM
CropDusterMan
19
Nov 3, 2012 06:39 PM
embry1123
Jul 27, 2010 09:12 PM
