Timing chain question
Old Oct 15, 2012 | 09:33 AM
Y-Blockhead's Avatar
Y-Blockhead
Originally Posted by ALL AMERICAN BOY
roverman
the turning the rotor 180 degrees is for other makes
where distributor shaft has screwdriver like blade at bottom.
you can turn y block rotor 180 degrees though.
What are you talking about? ALL distributors can be turned 180° Your just confusing the man with statement like this...
Old Oct 15, 2012 | 06:13 PM
ALL AMERICAN BOY's Avatar
ALL AMERICAN BOY
roverman
i keep forgetting to say:
you should put the timing chain gear marks
the way it shows in those pictures.
then something else came back to me.
when you drop in the distributor:
1 it doesn't matter really what distributor tooth you engage
with the camshaft drive gear.
just drop it in with adjustment travel in the middle.
rotor facing #1 plug, that's why the distributor has
the holdown clamp and has adjustment range.
2 when you drop it in, the bottom of distributor will
probably be standing on top of oil pump shaft.
put a finger on top of distributor and turn engine
just a little with remote starter and it will drop in and
engage with oil pump.
have a nice day!
dionysius
18
Jun 12, 2017 06:45 PM
LilBear'65
16
Mar 12, 2015 10:16 PM
mike L
May 16, 2008 10:42 AM
my69ford
Jun 1, 2006 12:10 PM
urif250
Nov 30, 2002 02:23 PM
