Bad sleazy t case noises?
Old Jun 25, 2012 | 01:12 PM
hunterstroble's Avatar
hunterstroble
Hi all, I'm new. I have a 93 f150 with 35k on it. 5.8 1/2 ton, Auto trans, electric shift t/case, factory auto hubs. It is all stock except for an aussie locker in the rear. Starting a few days ago, when I turn sharp and apply signifigant throttle, whe front diff engages, the front diff applies. Also small brake applications from a stop there is a small noise, hard stops, lots of bad gear noise. Could my t/case have broken a snap ring causing my stack up to shift. I was a GM guy so all this is new to me. It's wierd, I swear my front diff applies when I crank it and hit the gas in 2wd. I crawled under and turned d/shafts, made sure hubs spin free ect. But I can't really lay under it under a hard stop on flooring it and cranking it. Thanks all! The noises and clunk I'm feeling is not the aussie locker.
glen_melton
Jan 29, 2019 07:48 AM
dixie460
16
Nov 27, 2011 01:03 PM
PsD007.3
Jan 12, 2009 07:24 PM
fxstbchopper
Mar 10, 2008 06:28 PM
Ryan1522
Oct 6, 2005 08:32 PM
