Oil pressure question
Old Jun 25, 2012 | 09:33 AM
tshrager's Avatar
tshrager
I know that the oil pressure gauge is a glorified idiot light, but I noticed it fluctuating a bit the other day. Only a few hundred miles on fresh oil and I don't have a to get live data. Any cause for concern? Truck is running awesome, it loves the T6 full synthetic.
Old Jun 25, 2012 | 10:03 AM
madpogue's Avatar
madpogue
Live data wouldn't help you, since it's a simple analog signal that doesn't go thru the PCM. Does the fluctuation stop when you rev it up? Does it happen right away or only when it warms up?
Old Jun 25, 2012 | 10:22 AM
DIYMechanic's Avatar
DIYMechanic
Does the needle tick between 0 and the middle of the range or just twitch around in the middle?
Old Jun 25, 2012 | 10:50 AM
tshrager's Avatar
tshrager
Haven't noticed it cold, but definitely at temp. It just flickers a bit in the middle.
Old Jun 25, 2012 | 11:26 AM
fordpride's Avatar
fordpride
Clean the connection on the sending unit. It's on top of the hpop res.
Old Jun 25, 2012 | 12:59 PM
tshrager's Avatar
tshrager
Ok. I'll clean it and put a little dielectric grease in there.
Old Jun 25, 2012 | 01:32 PM
Talyn's Avatar
Talyn
bingo.
10char
Old Jun 26, 2012 | 12:12 AM
BuckHammer's Avatar
BuckHammer
Huh. Mine used to do this. Good information.
Old Jun 26, 2012 | 06:36 AM
Talyn's Avatar
Talyn
I first bought my truck and went to drive it home to michigan. The oil gauge bounced the whole way. 16 hours of bouncing. I was worried my truck was gonna explode.
Old Jun 26, 2012 | 08:17 AM
DIYMechanic
What did you do to fix yours?
Old Jun 26, 2012 | 08:23 AM
Talyn's Avatar
Talyn
I pulled the connector off and cleaned it.
I noticed that the sending unit likes to corrode no matter what you put on it, so I just hit it with an SOS pad every now and then, and I reamed out the connector with a small file, then pinched it with pliers so it connects better.
Old Jun 26, 2012 | 08:43 AM
Awitte58's Avatar
Awitte58
Edit: Shouldnt let my screen sit 20 mins... without refreshing before responding lol.
chris66
1983 - 2012 Ranger & B-Series
Feb 11, 2017 05:34 PM
jeffbradbury7
Jan 19, 2013 08:37 AM
nay_p0
Modular V10 (6.8l)
16
Dec 27, 2010 06:28 PM
xtrford
Oil & Lubrication
Nov 5, 2005 02:47 PM
samckernan
Feb 21, 2005 11:05 AM
