Sponsored by: Auxito
Lazy converter
Old Jun 25, 2012 | 08:45 AM
RHUIII's Avatar
RHUIII
Lazy converter
I have a 02' f150 v6 67,000 miles. When I come to a stop, the trans shudders abit like the converter is still locked up. It then goes to stall in a few seconds. this does not happen all the time, fluid is clean. I understand there is a simple fix for this, or is this normal?
Old Jun 25, 2012 | 06:44 PM
Bluegrass 7's Avatar
Bluegrass 7
I don't know it being a simple fix but the converter diode ring (one way clutch) is hanging engaged.
This causes a direct coupling through to the trans the same as a manuel trans.
Not normal.
The shudder is the same as not disengaging the clutch on a manuel.
Trans has to come out to effect a repair, if that is the problem.
Good luck.
emeraldcoupe
Jun 8, 2019 05:41 PM
Andrew LaFrance
Feb 17, 2019 07:36 PM
kabl_7
Oct 25, 2018 09:20 AM
titusf350
May 12, 2015 12:05 PM
Dieseladdict
Aug 13, 2006 06:39 PM
