Camper Special package
Old Jun 24, 2012 | 08:57 PM
rusbukt's Avatar
rusbukt
Hey all, Just started a new project. 65 F250 CC Camper Special. Been going through the mechanics of it. Four bent push rods and leaking rear axle seals. Havin fun now!
Question is what was so special about the Camper Special? Accessory's? One thing I came across was the sliding rear bumper. Was this AM or part of the CS package?
Also who is a reliable source for purchasing reman cyl. heads. for this 352? Gonna keep engine stock. Thanks for any info.
Old Jun 25, 2012 | 05:37 AM
jowilker's Avatar
jowilker
Mr. Wilson, can tell you better, but basically it is an add on package that would serve the purpose of hauling & using a slide in camper in the bed. Heaver springs, dual batteries, larger cooling, were some things included.
The bumper is aftermarket. It would be pulled out with the box in the bed.
Where are you located, maybe someone can recommend a local near you for the head work?
John
Old Jun 25, 2012 | 06:33 PM
rusbukt's Avatar
rusbukt
Thanks jowilker, That bumpers a little much. That'll be the first thing to go.
I'm in the Sacramento area. Half a world away from you. Don't know of any reputable machine shops around here.
Have you guys had any bad situations with these split rims? Are they even worth trying to get new rubber on them? Or should I just opt for newer style rims?
Old Jun 25, 2012 | 10:01 PM
tyfly's64's Avatar
tyfly's64
im in vacaville and there is only one shop that would touch my truck which is cme auto repair
Old Jun 26, 2012 | 04:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/66 F100/250 Camper Special package included: Dual Western mirrors, unique Camper Special front fender emblems, 300 I-6 or 352 V8, 4 speed manual or Cruise-O-Matic, oil & amp gauges, xtra cooling radiator, H/D springs/shocks, extended tailpipe, 70 amp battery, pigtailed wiring harness/plug for camper clearance lights.
All rear bumpers were optional, Ford didn't offer step bumpers till 1967, none were the extending type.
Originally Posted by jowilker
dual batteries.
John: FoMoCo didn't offer dual batteries until 1973. If previous years have them, they usually were installed by RV dealers.
Old Jun 26, 2012 | 08:35 PM
rusbukt's Avatar
rusbukt
Thanks tyfly. I'll check into them. The truck had been sitting so long that the valves froze-up. I broke them loose and will throw a set of new push-rods in and keep my fingers crossed for now.
Old Jun 26, 2012 | 08:37 PM
rusbukt's Avatar
rusbukt
Numbers! As always your a book of knowledge. Thanks! And good to hear from you again.
Old Jun 27, 2012 | 03:30 PM
pburress's Avatar
pburress
The split rims are dangerous to work on due to the tension in the ring holding it together. Most shops won't/can't work on them. I'd recommend replacing them.
Old Jun 27, 2012 | 09:41 PM
tripleframe's Avatar
tripleframe
Allowed the customer to purchase a pickup designed for camper hauling from the factory. There were 3 different levels of F 250 Camper Specials to choose from. The F 250 Camper Special package was actually introduced late in the 1964 model year run ( the straight axle Camper Specials were very rare).
alvald83
Jun 5, 2012 12:30 PM
thenap1
Feb 4, 2011 04:33 PM
jonsk
Sep 11, 2010 07:58 PM
bugman78f-250
Apr 4, 2007 05:47 PM
storme
Feb 18, 2004 08:04 PM
