E4OD Separator Plate
Old Jun 24, 2012 | 03:50 PM
PvtTarget's Avatar
PvtTarget
The first metal plate to go down ( large one ). I am building to be a 1996-1998 setup. I am wondering what the difference is between the two plates from 94 to 97. The plate from the 97 got rusty an now unusable, can I use the 94 plate instead thanks very much Robert
Old Jun 25, 2012 | 07:57 AM
DIYMechanic's Avatar
DIYMechanic
Robert, I'm not sure what separator plate you're referring to. Can you clarify your question a little bit for us?
Old Jun 25, 2012 | 10:01 PM
PvtTarget's Avatar
PvtTarget
The gasket goes down then this plate an at tail end there is a reinforcing plate bolted down. Also this plate has square, round, an or triangle notches cut out here at where the reinforcing plate goes. If this doesn't do it I will take a picture of it thanks in advance. Cheers Robert
Old Jun 25, 2012 | 10:09 PM
fordpride's Avatar
fordpride
I think we are gonna need a pic.
Old Jun 25, 2012 | 11:33 PM
PvtTarget's Avatar
PvtTarget
http://www.makcotransmissionparts.co...E4OD-4R100.pdf
If ya look down page towards bottom number 747 .
Thanks for the help
Old Jun 26, 2012 | 06:25 AM
fordpride's Avatar
fordpride
Call these guys they should be able to help you.
Click on the blue
https://racerxusa.com/
nut1605
Oct 31, 2007 05:13 PM
YOMAN
2004 - 2008 F150
Aug 29, 2004 08:33 PM
