carb problems
Old May 7, 2003 | 08:58 PM
wats's Avatar
wats
carb problems
I have a 1976 F-150. My problem is adjusting the carb. one side of the engine blows out white smoke. does it need more fuel or less. Any advice on carb adjustment is greatly appreciated.
Old May 8, 2003 | 01:08 AM
Ford_Six's Avatar
Ford_Six
carb problems
Welcome to FTE-
I do need a little bit more info- how much white smoke, does it linger a little, only in certain weather conditions, etc. Also, have you already tried adjusting the idle mix screws?
Old May 8, 2003 | 09:24 AM
wats's Avatar
wats
carb problems
It blows just enough to see it. I have adjusted the screws some but I am not shure what it needs. I don't think it is an engine problem because it still smokes the same when the engine gets hot, but I am a newby. I hope this helps some
Old May 8, 2003 | 02:06 PM
millertime300's Avatar
millertime300
carb problems
That isn't a carb issue. Do a commpression check, and inspect you spark plugs while you are at it. You probably have a leaking head gasket.
Old May 8, 2003 | 02:27 PM
macguyver's Avatar
macguyver
carb problems
Or it could be the vacuum modulator leaking a small amount of tranny fluid into the intake.
Old May 8, 2003 | 10:25 PM
CLUMP's Avatar
CLUMP
carb problems
I agree with millertime300 you are most likely passing coolant into the cylinders
Redneck smoke diagnostic's
Black smoke - excess fuel running rich
Blueish white/gray smoke - oil burning
White smoke - coolant burning
Old May 8, 2003 | 10:45 PM
millertime300
carb problems
If you run antifreeze in you radiator and let your truck idle in thedriveway for a while you might even notice the liquid that dips out of the exhaust is greenish.
Does it ever have trouble turning over after it has set for a while? Do you have bubbles surfacing in your radiator fluid?
Old May 9, 2003 | 05:38 PM
wats's Avatar
wats
Thumbs up carb problems
Thanks guys ...I think the consensus is the head gasket. It does blow out green antifreeze. It is leaky and old, so I am going to replace it and see if it improves.
gudone
Apr 15, 2022 10:53 PM
69 F-350 Wrecker
Jun 11, 2014 11:29 AM
FordTroutCatcher
Aug 5, 2012 08:08 PM
mybrownie
Sep 1, 2009 02:38 AM
cwethy
Sep 8, 2003 12:22 AM
