QUICK!!!!! Fuel filter wireing harness
Old Jun 23, 2012 | 09:32 PM
Redneckmorton's Avatar
Redneckmorton
I just replaced everything and forgot where the two little round plugs go. I stuck them where I thought they did and now when I turn the key on the Fuel Filter light comes on, on the dash.
Old Jun 23, 2012 | 09:39 PM
Talyn's Avatar
Talyn
Which 2 round plugs where?
Old Jun 23, 2012 | 09:40 PM
Talyn's Avatar
Talyn
are you talking bout on the fuel bowl?
The only wires that are important on the Fuel bowl harness are the ones going to the IPR.
Old Jun 23, 2012 | 09:46 PM
Redneckmorton
maybe i got it backwards going to the IPR then. Let me check.
So I know there is one going to the fuel heater, but there is two round ones. One goes to the water thing and the other goes to??? But I don't know which round one goes to the water and what the other round one goes too
Old Jun 23, 2012 | 09:52 PM
nomad221's Avatar
nomad221
http://www.dieselorings.com/docs/OBSFuelBowlRebuild.pdf
should help ya.
Old Jun 23, 2012 | 09:58 PM
Redneckmorton
Originally Posted by nomad221
Followed that one, but it don't have the wires in it..
I guess It was cause I had the water sensor hooked up. Unplugged it and the light went off.
I must of done something right today. It fired right off for me.
Old Jun 23, 2012 | 10:24 PM
Talyn's Avatar
Talyn
Yeah, long as the IPR is plugged in, which you cannot screw up unless you cut off the wires, it will fire up.
Old Jun 23, 2012 | 10:50 PM
Redneckmorton
Well I did something wrong.
Its just pouring out now.
And yes the drain is closed.
It wasn't leaking before I left the house, or at least not this bad. I even let it idle in the drive way and reved it up and held it at 2grand for a bit with no leaks.
HMMMMMMMMMMMM
I'll let it cool off for the night and get back on it in the morning I guess.
Old Jun 24, 2012 | 07:03 AM
Talyn's Avatar
Talyn
Did you remember to tighten the hose clamps on the very bottom of the fuel bowl to the pump?
Old Jun 24, 2012 | 10:11 AM
Redneckmorton
What is this and where can I get one?
I have seemed to have lost it and the reason I couldn't figure out where the other wire went last night.
Which tells me it was leaking last night before I drove it. But some how over looked it the first time.
Old Jun 24, 2012 | 10:23 AM
Redneckmorton
never mind. I just realized what i did. It was the only piece that was to be wiped clean and not soaked in cleaner. I don't know how I over looked it this morning as it was sitting about two inches from my laptop. I just so happened to think about it this morning while talking to my mom and jumped up knowing right where I set it.
Dans2Fords
Feb 22, 2012 06:06 PM
2005f-150
Aug 14, 2010 11:27 AM
RRranch
Mar 21, 2009 02:15 PM
Pele
Aug 26, 2007 11:00 PM
whimsy
37
Sep 27, 2006 06:33 PM
