428 SCJ on CL
Old Jun 23, 2012 | 03:36 PM
FordmanShane's Avatar
FordmanShane
428 SCJ on CL
Im going to check out this crank, cylinder head and block. the crank has to be a 1U right?? what's your opinion? what parts and casting nubers should I be looking for? apparently this block was supposed to go into a 74 f250..but the owner passed away so the wife is selling everything...she's asking $15,000 for the truck!
Old Jun 24, 2012 | 08:53 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
SCJ crank is stamped 1UA. The one in that ad is not a SCJ crank. It has the small weight on the counterweight. SCJ's do not have the CW there. That one is a 1U or 1UB CJ.
CJ heads are C80E-6090-N castings most of the time. Keep in mind they made these as service parts well into the later 70's. So date codes can be very late or not even on them. Not a big deal in a non numbers correct situation.
The block is the same as a CJ 428. 68.5 to 70 production. His ad says it's a 69. Service blocks were cast well into the 70's.
Check this site out. Mustang 428 Cobra Jet Registry click on "engine information" box then component ID and you'll see the parts ID page. It'll give you some good info going in. These parts can get $$$$ so you need to know exactly what your buying. They show the difference in the CJ/SCJ cranks. and tons of other stuff, heads, blocks etc....
Old Jun 24, 2012 | 08:59 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Also that's a good price on the CJ crank. They can go .060 but if it's std to .030 and needs a cleanup still ok with no major damage. Heads for $500 not bad either. Check the thumbprints to see how much they've been milled.
Old Jun 24, 2012 | 03:55 PM
FordmanShane
Thanks for the reply! I have one more Q.. How would one store a crank shaft?
Old Jun 24, 2012 | 04:00 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I store mine standing upright on the flange. Oil down the journals well and bag it.
Old Jun 24, 2012 | 04:19 PM
FordmanShane
Your assumption was correct the crank is a 1u! im hella excited!!
Old Jun 24, 2012 | 05:37 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Nice. How did the other stuff look?
Old Jun 26, 2012 | 12:54 AM
FordmanShane
just a little dust n rust..
FordmanShane
Jun 23, 2012 11:41 PM
muscletruck
Apr 12, 2009 02:13 PM
OldFordRacer
Oct 27, 2007 10:26 PM
FirstTry
Jul 16, 2006 08:05 PM
anotherF150
Feb 7, 2004 07:48 PM
