UVCH Install
Old Jun 23, 2012 | 02:46 PM
1L243's Avatar
1L243
UVCH Install
Today I started with the Drivers side with new OEM UVCH and valve cover gasket install. 10 months ago I did the factory plastic shim for the UVCH. The problem was fixed till about 3 months ago. Every once in a while I would loose one side. Turning the engine off and on would fix it and it would run right again till the next time. I decided against the 50 cent mod, just did not like the idea just incase the plastic clip the holds the quarter in should break.
What I discovered today is that the factory OEM plastic shim is gone! The connector was slightly apart. Removed old harness and gasket and installed new harness and gasket. May do the other side today or tomorrow. Have not got it completely button up yet, will see how she runs in a few...
My thoughts skip the OEM clip!
Old Jun 23, 2012 | 03:12 PM
4EXTRDR's Avatar
4EXTRDR
I glued a few of my trucks because this was happening...works great, go Gorilla Glue
Old Jun 23, 2012 | 07:53 PM
1L243's Avatar
1L243
RETRACTION!!!!
The OEM clips WERE NOT MISSING. At first glance I did not see the clip but later when I got to check it out closer the clamp was there. Even with the OEM clip/wedge the drivers side connection was apart enough where I could push it back together and see it close. The passenger side was tight.
My thought is that the OEM clip/wedge is a temporary fix at best. Do it right the first time and replace the harness and valve cover gasket.
Old Jun 23, 2012 | 10:40 PM
Stewart_H's Avatar
Stewart_H
The ones I put on my Ex have been holding tight for over four years now.
Stewart
jpcjguy
Jun 3, 2010 08:41 AM
luny1
Dec 4, 2009 10:09 AM
97biostroke
Jan 20, 2009 09:21 PM
blrman1962
May 28, 2007 06:40 PM
Idaho rockhauler
Jan 24, 2003 02:12 PM
