Looking for some help
Old Jun 23, 2012 | 02:33 AM
Tattyjoe's Avatar
Tattyjoe
So i recently swap out a c4 with a c6 in my 63 with a 1978 302 from a f100. Every thing seems to be ok but when i press on the gas it bowgs out and jumps forward and stops jumps forward stops ect. Do i need to turn the mod valve and calibrate it to the 302 some how since the c6 used to be on a 351, or did i miss something simple.
Old Jun 23, 2012 | 03:58 AM
jowilker's Avatar
jowilker
TJ, Do you know if it was operating smoothly in it's donor? Has it setup for a while? How does it shift from a normal start from a stop to 40+ mph?
I did some adjusting on mine when I first got it. My experience with the adjusting it moved shift points up or down.
Was your engine running/working like it should with the C4? Did you pull it and run the C6 in like a few days time?
I'm thinking engine vacuum but hopefully better help will be along shortly.
John
Old Jun 23, 2012 | 08:51 AM
rogue40's Avatar
rogue40
I'm assuming "bowgs" is a typo for bogs. If so, is it the engine that is bogging down? Is the engine rpm being dragged down as if your truck were tied to a tree?
From what I gather from your post I'm leaning towards a vacuum issue also. Check all the lines from the carb to the modulator. Put a separate line on the modulator and suck into it to see if the diaphragm leaks, if so then you need to replace the modulator.
How big of a carb are you running?
Old Jun 23, 2012 | 10:34 AM
Tattyjoe's Avatar
Tattyjoe
stock carb from a 78 f100. The c6 was sitting for a long period of time. The 302 was good before the switch. I will check the lines right now
Old Jun 23, 2012 | 11:05 AM
Tattyjoe's Avatar
Tattyjoe
lines are good, maybe i just have to run it for a bit to get the cobwebs out?
Old Jun 23, 2012 | 11:21 AM
Tattyjoe's Avatar
Tattyjoe
Yes the engine boggs down like there are no rpms and then jumps forward, no leaks on the modulator. the carb is a stock two barrel from the 1978 302
Old Jun 23, 2012 | 02:28 PM
jowilker's Avatar
jowilker
TJ, Where did you connect the mod valve vacuum hose to on the engine?
Try disconnecting it and see what happens.
That tranny setting up for a long period could be an issue but shouldn't affect the running of the engine.
John
Old Jun 23, 2012 | 09:22 PM
Tattyjoe's Avatar
Tattyjoe
John
Did that and the same thing happens nothing really changed except it dies alittle quicker when i put it in to drive
Old Jun 24, 2012 | 04:20 AM
jowilker's Avatar
jowilker
And where did you connect the hose to? A vacuum issue with the carb is speaking louder.
Have you relocated any vac hoses?
John
Old Jun 24, 2012 | 10:40 AM
Tattyjoe's Avatar
Tattyjoe
John
The intake where it was before never touched it, well on that end. I will take a pic.
Old Jun 24, 2012 | 11:52 AM
Tattyjoe's Avatar
Tattyjoe
Old Jun 24, 2012 | 12:40 PM
old broke prospector's Avatar
Tattyjoe,
I am thinking distributor advance problem.
If you have eletronic ignition it will do this. As the advance moves, it pulls on the wiring, if there is a break in the wiring, it will bog the engine. When the advance returns to original position, the wire reconncts and lets the engine run. I have never see this happen with standard points but it could, more likel by grounding as it advances
If not that distributor advance, I would check for vacume leaks by spraying starting fluid at all connections. It will rev higher when you spray the leak.
Good luck
Dennis
Old Jun 24, 2012 | 12:56 PM
Tattyjoe's Avatar
Tattyjoe
Originally Posted by old broke prospector
Tattyjoe,
Good luck
Dennis
Thanks dennis i will give it a try.
Old Jun 26, 2012 | 08:52 PM
Tattyjoe's Avatar
Tattyjoe
Ok so i put new lines on it and now it goes forward back all good untill I get the rpms up and then it dies it makes like crackling noise and then it just dies, anybody got a clue or if not anybody want to buy a 63 f100 arrg!!
Old Jun 26, 2012 | 09:49 PM
I hate to go down the curvy guessing game road without listening to the engine but I would replace coil and spark plug wires in this case.
Wires will fail under load at high rpm.
Good luck.
