trans temp gauge
Old Jun 22, 2012 | 11:10 PM
bieryj's Avatar
bieryj
trans temp gauge
I have a 93 F150 and I want to put a trans temp gauge on it for pulling grain wagons and such. It has the e4od trans. I was looking for suggestions on a gauge and where to put the sensor for it.
And another question. For mirrors I have the non power mirrors on the A-frame type mount, is there an extension for a tow mirror?
Old Jun 23, 2012 | 08:18 AM
XLT89F350cc's Avatar
XLT89F350cc
the temp sending unit should go in the pan. when you buy a gauge the instructions will tell you exactly where to put it. LMC has extention towing mirrors the clip over these mirrors
Old Jun 23, 2012 | 12:41 PM
oleman's Avatar
oleman
I would put the senser in the output cooler line. Make sure it is in the fluid.
A Tee in the line normally works.
Too make it easy some aftermarket oil pans has a temp sensor boss machined in if you want it in the pan.
Old Jun 23, 2012 | 12:53 PM
Lead Head's Avatar
Lead Head
E4ODs have a pressure test port thats capped off on the drivers side of the transmission. Most transmission temperature gauge senders will probably have a sensor that can screw right into the test port - the one we installed did.
We compared the temperature the gauge reported to the one the internal sensor on the solenoid pack reported, and they were pretty much spot on.
Old Jun 23, 2012 | 01:30 PM
bieryj's Avatar
bieryj
What sender did you use?
Old Jun 23, 2012 | 01:50 PM
Lead Head's Avatar
Lead Head
It came with the gauge. It was "Glow-Shift" brand.
slinginsaws
Oct 28, 2014 04:12 PM
bstarz40
Feb 9, 2014 12:16 AM
Shake-N-Bake
26
Jul 4, 2010 02:16 PM
bad12jr
Mar 15, 2009 10:12 PM
