Tires
Old Jun 22, 2012 | 03:19 PM
White Boy's Avatar
White Boy
Tires
i have a 1978 ford f150 4x4 i have no lift but installed bush wacker cut out fender flares on it i was wondering what size tires i can go up to i have 15x8 rims any help would be appriciated..when i bought truck it had 33's on it with no fenderflares
Old Jun 22, 2012 | 03:46 PM
Boss Hogg 87's Avatar
Boss Hogg 87
You could fit 31'' tires no problem. I know some people that have 33's on stock suspension but when taking corners they do rub slightly. I have a 4'' lift on my 87 and it is rated to fit 35's but my 33's rub on the radius arms on sharp cornering
Old Jun 22, 2012 | 03:51 PM
White Boy's Avatar
White Boy
tires
i have 31's on it now with no problem..it had 33s when i bought it withno problem.. nowi wanna do 35s but dont know if they will work
Old Jun 22, 2012 | 03:57 PM
HIO Silver's Avatar
HIO Silver
Typically, 33x12.5x15s will fit on 15x8s with no rub.
When I got my truck, it had a 2-inch lift and fit 35x12.5x15s on 15x8 wheels and no rub. However, tires vary between manufacturers even though they are sized the same... Some have bulged sidewalls whereas some are more vertical like my Goodyear Wranglers.
My rig now has a 4-inch lift and is visually more proportioned. It's a trail runner - not a mudder:
Old Jun 22, 2012 | 04:27 PM
White Boy's Avatar
White Boy
But will 35's fit with bushwacker cut out fender flares
Old Jun 22, 2012 | 05:21 PM
JB78f150's Avatar
JB78f150
I think they would fit but there will be rubbing on the radius arms.
Old Jun 22, 2012 | 05:23 PM
White Boy's Avatar
White Boy
Ok thanks for the help
Old Jun 22, 2012 | 08:31 PM
NW 150's Avatar
NW 150
Also to keep in mind is the wheel offset.
Old Jun 22, 2012 | 10:20 PM
neondr's Avatar
neondr
I would say 33's. You may fit 35's would be awful close 1 speed bumb may rip a fender or two. Flare don't raise the truck.
Old Jun 23, 2012 | 10:17 PM
Coleman77's Avatar
Coleman77
We had 36s on mine stock. if that helps any, it all depends on how much rubbing you want to hear/feel
txjfrosty
Oct 21, 2014 06:35 PM
boggerted
Jul 19, 2008 06:30 AM
hapkidoman
Nebraska Chapter
Apr 22, 2008 10:39 AM
rc351w
Feb 1, 2001 06:33 PM
Snapper_Rider
Sep 2, 1999 02:33 PM
