Anyone know where to pick up a trailer light connector adapter thing? If anyone has an extra one lying around, I wouldn't mind buying it if it's in good shape. Thanks.
e trailer . com www.etrailer.com/
when it comes to trailers amd everything that relates you need to ck this place out,they literally have it all,its in my favorites
ebay, tractor supply, etc. depends on what you need. 4 flat, 7 pin no brakes, etc. and whether you want to tap the wires or are looking for a plug in. brakes will need a brake controller....
Do you mean the connector that goes into the factory wiring harness so you don't have to 'hack' the wires to install a plug? If so, NAPA carries those. It comes with a plug that goes between the factory connectors and an extension to run to the bumper.
