Cowl
Old Jun 22, 2012 | 01:18 AM
stevenjakeryan's Avatar
stevenjakeryan
Cowl
Hi everyone , after removing my engine for a rebuild i found flaky rust under the cowl area and after prodding and scraping at it its more advanced than i hoped for ....going right through into cowl gutter area which will need cutting and replacing of. My question is has anyone completely removed the cowl to do proper repairs and any pics i could look at . After studying it , im guessing screen out , gaurds off , drs off and unpick spot welds and should pop off. cheers steve.
Old Jun 22, 2012 | 08:15 AM
earthquake68's Avatar
earthquake68
That sounds about right. There's no easy way to do involved work. Take your time, do it right the first time, and don't take out too much metal without bracing the cab. You should be ok, but if the rot is too bad, when you're done cutting the rust out, you could let the front of the cab relax enough to distort where the windshield goes. Just keep an eye on the bottom of the glass when you're cutting. If you think it's gonna move around, stop and tack weld in a brace or two.
Old Jun 22, 2012 | 08:38 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I doubt you'll have to go this far but if needed there are still three NOS cowl panels available.
Panel, cowl top
Fits 73-up F100-350
D8TZ-1002010-A
JST Automtive, Lebanon, TN has 1 (615) 443-3086
Green Sales, Cincinnati, OH has 1 (800) 543-4959
Don Sanderson Ford, Glendale, AZ has 1 (623) 842-8643
gstirewalt
Sep 29, 2014 08:09 PM
young66
Jun 22, 2010 04:39 AM
77red4x4
Paint & Bodywork
19
Oct 25, 2006 05:55 PM
gatorfan
Paint & Bodywork
Sep 23, 2004 09:04 PM
F250Rob
Jul 31, 2004 03:56 AM
