Help with new radiator. Project Completed!
Old 06-23-2012, 02:05 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Originally Posted by akamacgyver
I have a lot of other plans for this thing, like; Intercooler, banks, 4" exhaust, ect.
Mac.
fixed a little bit for ya there.
Old 06-23-2012, 03:05 PM
akamacgyver's Avatar
akamacgyver
akamacgyver is offline
Clueless spectator!
Your killin me Smalls! You are relentless! I'm leaning towards the down pipe again!
Old 06-23-2012, 03:13 PM
FORDF250HDXLT
yeah i noticed that lol.stop that or you'll be full of regrets latter.
it's just one miserable,hard weekend brother,then it's all over for years to come.
So I might as well get this repair behind me.
Mac.
Old 06-23-2012, 06:41 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
And 94,
Thanks for the info. I still have my 93 for transpo. and the 94 runs well enough, the trans only overheats when I'm wheeling, so I'll give Champion a chance. Like I said, it won't even come off the truck if the packaging is damaged. Did yours come with a cap, and if so was it worth a darn?
I think I will go with the Autozone water pump. I put one on my 93 2 years ago and it is still going strong. I always prefer new over rebuilt because I have heard stories about some rebuild companies fixing only the failed parts in the cores and not refurbing the entire thing. New is new! Plus no core to deal with is nice!
yes, my champion rad cam with a 16lb cap, same as what was on the truck when i got it. had the original cap on it. when i got my 2nd alluminum rad it did not have a cap so i used the ford cap that was on the truck. i kept loosing the extra little bit of coolant out of the puke tank. replaced cap with the champion cap and have not had a single issue since. i tested the old cap at school and it did not build up pressure good and would not hold.
i to went with the a-zone h2o pump. have not had any issues with it. i was told that it was actually a very good quality pump.
let me get you some pics of my second rad. it is a Sila all aluminum radiator. quality looks just as good as the champion rad. packaging was good. that one cost me $310 iirc.
Old 06-23-2012, 07:00 PM
Rxracer27's Avatar
Rxracer27
Rxracer27 is offline
Here are pics of my ebay radiator:
was packaged with Styrofoam also.
Rob
Old 06-23-2012, 07:03 PM
'94IDITurbo7.3
Old 06-23-2012, 07:07 PM
'94IDITurbo7.3
Holy hell Rob lol.
when i went to post my pics you had not yet posted yours. when i got mine posted yours showed up and i thought it was kind of weird how the backgrounds on my pics magically changed, then i realized what happened lol. yours looks identical to mine.
Old 06-23-2012, 07:13 PM
Rxracer27's Avatar
Rxracer27
man that does look identical to mine! although mine was only 220 shipped to my door..
so far im more than happy with the radiator. did u get the large 2 row or the 3 row? i chose the 3 row when i did mine it was also around 12 dollars cheaper FWIW
Rob
Old 06-23-2012, 07:19 PM
'94IDITurbo7.3
pretty sure it is the 3-core.
Old 06-23-2012, 07:33 PM
FORDF250HDXLT
the idi engine requires a 13 lb cap actually.
Old 06-23-2012, 07:39 PM
'94IDITurbo7.3
i have read that but i have not had any issues with the 16 lb cap. temp stays right at 190*F
Old 06-23-2012, 08:53 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Not to hijack, but im diggin the looks of them radiators, i wasnt aware the aftermarket ones were quite so affordable. Are those comparable in dimension to the IDI radiators? I have the 79 super-cooler but it is shot and im kinda torn where to go with this. Planning E-fans and IC so i need some room, which a more efficient smaller rad. might just do the trick.
  #28
Old 06-23-2012, 09:02 PM
'94IDITurbo7.3
my rad fit great. ZERO modifications to the rad or the rad support/mounting had to be done.
  #29
Old 06-23-2012, 11:25 PM
akamacgyver
Clueless spectator!
Hairy, it is a direct bolt in for our IDI radiators, identical in size. None of us knows how much room you have to work with though. I am also planning electric fans and an IC, I might try to get them behind the radiator, I need to do some research first though. All that will need to wait until I get to Denver.
  #30
Old 06-24-2012, 01:12 AM
hairyboxnoogle
As i remember it, my rad is quite a bit taller, but a bit narrower than the IDI rad. Ideally i would want the height / width of both, but honestly.. guess im going to have actually sit down and think about it, measure mine, measure an IDI rad, measure the inter-cooler etc. Something i need to get on.. as currently towing is out of the question, and she likes to get warm on even small hills. However, i know the 7.3SD cooler works with the IDI rad, and i was planning on just swapping in a IDI rad anyway... dont see how its any differnt to just ordering up a new one. My radiator new is $486 + 137 for fan clutch, OR... 2xx for alum and 50 for e-fans.
Quick Reply: Help with new radiator. Project Completed!
