292 electronic ignition
Old Jun 21, 2012 | 09:54 PM
halltm's Avatar
halltm
Just rebuild my 292 had points in it. It was running very rough but always fired up on the right away. I put a pertronix and new coil in yesterday. The trucks runs great and is now difficult to start and heistates to turn over.
Any thoughts why??
Old Jun 22, 2012 | 12:27 PM
HT32BSX115's Avatar
HT32BSX115
Any thoughts why??
Howdy,
That has happened to me on my current truck (when I had the 239 in it) and many years ago when I had my 57 Ford Fairlane as a teenager!
In BOTH cases, I had a couple of plug wires "switched" and the engine "seemed" to run fine!
It was VERY difficult to tell that it was only running on 6 cyls!
Cheers,
Rick
Old Jun 22, 2012 | 03:32 PM
charliemccraney's Avatar
charliemccraney
Did you follow the installation instructions?
Have you checked the timing?
Old Jun 22, 2012 | 09:14 PM
halltm's Avatar
halltm
I will recheck the wire. Currently I have a very high idle that I cannot bring down any further.
Old Aug 26, 2012 | 07:20 PM
Tedster9's Avatar
Tedster9
Does your truck have the resistance (pink) wire? Some Pertronix and Ignitor coil types have that bypassed iirc, depends. Make sure you have a fully charged battery, too. You almost have to use an outboard charger if you're still running a generator.
Points work OK, but the Pertronix plus one of those flamethrower coils will run WAY better.
yayhelicopters
May 16, 2014 09:25 PM
rdweathers
17
Feb 27, 2012 09:47 PM
steve664x4
May 21, 2008 11:23 PM
qman
Nov 14, 2004 06:37 PM
paulmal
Electrical Systems/Wiring
Aug 23, 2002 05:18 PM
