waterb pump
Old Jun 20, 2012 | 09:44 PM
fordpride's Avatar
fordpride
Unhappy waterb pump
well afterb 235k my water pump puked with no warning. I was crusing then noticed my temps go up to 225* so i pulled over got out with truck still running and look under the front and it looked like a water hose was on. water blowing out of the weep hole
i was planning on doing a coolant flush and hose's this weekend. guess i ccan add pump to that list. can you guys think of anything else that needs to be done?
Old Jun 20, 2012 | 10:02 PM
ReBilld's Avatar
ReBilld
Have you cursed a lot yet? I'd go ahead and do that and get it out of the way. Sorry to hear about your water pump
Old Jun 20, 2012 | 10:16 PM
oldbird1965's Avatar
oldbird1965
Is your thermostat good? Don't do what I did and ding the radiator. Put cardboard in there to protect it. I did some curseing but it didn't help. I'm still missing a wrench though.
Old Jun 20, 2012 | 10:21 PM
ReBilld's Avatar
ReBilld
If you've ever considered doing the dual tensioner mod, this would be a good time to do it.
Old Jun 20, 2012 | 10:22 PM
pjwoolw's Avatar
pjwoolw
Good time to reseal the HPOP gear / bolt cover if its seeping.
Old Jun 20, 2012 | 10:24 PM
madpogue's Avatar
madpogue
Thermostat, possibly the housing. Maybe one of those heavy-duty flanges that reinforce the flange on the housing. Maybe a new res cap. Don't forget the SCA (or get pre-charged).
Option - IH water pump with integral filter base.
Old Jun 20, 2012 | 10:40 PM
fordpride's Avatar
fordpride
I did alot of cursing
I got a 203* that's about a year old
Don't need the dual tensioner mod my belt wears perfect
I put in the HPOP from Glenn a few months ago and everthing is sealed tight
T stat neck is only a couple months old
I'll be using fleetgaurd pre charged
Res cap ?
Old Jun 20, 2012 | 10:57 PM
Talyn's Avatar
Talyn
Ignore the res cap, i dont think he realized you had a 97.
Like PJwool said, Do the HPOP gear cover while your in there.
You can be cool like me and just leave the fan off too.
Old Jun 20, 2012 | 11:33 PM
glovemeister's Avatar
glovemeister
Is that IH pump hard to install? My pump isn't leaking, but I figure I should replace it, as I don't know the history on it. Temps are good though I just want to get stuff done before winter as I have no shop and outside in the cold sucks.
Old Jun 20, 2012 | 11:34 PM
Talyn's Avatar
Talyn
The one IH Pump has a built in filter head.
If you have to replace the pump, i suggest going with the IH pump, filter or non filter version.
Old Jun 20, 2012 | 11:36 PM
Talyn's Avatar
Talyn
Water pump is a snap if you got the fan removal tool.
few bolts on the shroud. pop the fan off, be sure to block the radiator with plywood.
Well, drain coolant first, make huge mess.
few bolts on the system and whammo, its out.
15 Ft Lbs is the tq on them IIRC.
I can probably change a water pump on our trucks in an hour now after i have the fan and shroud off.
Old Jun 20, 2012 | 11:40 PM
tshrager's Avatar
tshrager
Clay has motorcraft pumps for 150 right now
Old Jun 21, 2012 | 02:45 AM
madpogue's Avatar
madpogue
'97 has the cap on the radiator?
Wouldn't leaving the fan off make him hot like you??? (or warmer ...)
Old Jun 21, 2012 | 06:13 AM
427 fordman's Avatar
427 fordman
I don't see a coolant filter in your sig Mike. Now would be a good time if you want one.
Old Jun 21, 2012 | 06:24 AM
ccarrier's Avatar
ccarrier
lol, fan removal tool?
just use an air hammer with a good blunt bit.
those auto parts store loaner "wrenches" are a joke
