'79 Ford F-150 Starter stuck
you could do that, but that function is already built into the ignition switch. I know electrical problems are frustrating and can be difficult to diagnose and repair, but I don't see the point in running duplicate wiring. The correct fix is to find the reason the key isn't actuating the solenoid, and its gonna take using a multimeter or at least a test light to find out what is going on. At this point in time it sounds like it could be the solenoid, but you'd have to know if the switch is even actuating the solenoid to make sure there isn't a wiring problem somewhere between the switch and the solenoid.
Ok here is some more info the radio is also not working and it was working before but is not now and the wipers are also not working on accessories or run, but here is something really weird if I turn the steering wheel back and forth the wipers work but I have to keep working the steering wheel! WTF! I don't know what is going on but I know I am wore out with it!!!!
Thanks for the help. Thats kinda what I have been thinking about my issues, but it has a manual transmission and there are not many wires in the steering column 4 I think but the only thing that is electrical is the horn and the signal, so I guess it must be either one of those. But the horn doesn't work, not sure about the turn signals so I will start with the horn.
sgauvry
41
09-28-2015 03:42 AM
tjdad62
02-02-2015 12:20 AM
bigtuna
09-20-2013 03:50 PM
Ryokotsusai
10-13-2006 11:47 PM
