AC leak???
Old Jun 20, 2012 | 10:54 AM
Shwan_89HD's Avatar
Shwan_89HD
AC leak???
I drive a 89 F250 351w and recently charged my AC, so now its working fine. But ive noticed when i turn off the truck there drops of what looks like clear water leaking... It only does it when i have the AC on, when i dont run the AC it doesnt do that. Could yall help me out?
Old Jun 20, 2012 | 11:20 AM
rla2005's Avatar
rla2005
It's called condensation, it's perfectly normal. The hot humid outside air is drawn passed the cold evaporator, the moisture in the air falls out of suspension it has to go someplace.
Old Jun 20, 2012 | 11:32 AM
92 Black Nite's Avatar
92 Black Nite
If it is water dripping under the Passenger side of the engine bay. Then it's just the A/C evaporator . The there is a lot of moisture being pulled out of the air which is normal . It would be the same as a window A/C unit that is dripping. So if is dripping water under the Pass.Side you are fine.
Old Jun 20, 2012 | 01:14 PM
Shwan_89HD's Avatar
Shwan_89HD
Ya thats exactly where its leaking. K thanks yall
Old Jun 20, 2012 | 11:33 PM
wolfy's Avatar
wolfy
Yep. Same thing as an ice cold coke can that sits outside. It drips from condensation. Same principle
emmagator
Nov 7, 2013 08:23 PM
CptSD
Jun 29, 2011 05:56 PM
cosmicbrian
Mar 6, 2007 09:55 PM
Rintin69
Jun 9, 2006 06:14 PM
deltasoft
Jun 15, 2004 09:13 AM
