My 76 F250 Supercab doesn't have cab lights. I believe a truck isn't a truck without them so I'm looking for an OEM set with harness. Any of you guys know where I might find something like that?
You're asking for roof mounted clearance lights, correct?
There were two different styles used in 1976, both are obsolete, but can be found NOS.
I dunno if anyone has the wiring harness as it's also obsolete. One a the obsolete parts locator sites I use is down for maintenance, will take a look-see when it wakes up.
Yea the roof mounted clearance lights. I've always just called 'em cab lights, sorry. That'd be awesome if I could get a set. What's the difference in the 2 styles? Thanks again!!
I was going to put a set on my truck, and couldn't find any that didn't look their age. I got a new set at NAPA that are an exact copy, look at the picture bottom left of my post. I ran a wire across the lights ans tied them all in together and and ran the wire down the A pillar, and tied into the brown parking light wire on my light switch. looks original, and never a problem.
DOTZ-15442-A .. Clearance Lamp Assy / Amber / Tear Drop shaped / roof mounted / includes socket/feed wire / less wiring harness / Obsolete / 85 available NOS
DOTZ-15464-A .. Clearance Lamp Lens only / Amber / Tear Drop shaped / roof mounted / Use with DOTZ-15442-Aonly / Obsolete / 72 available NOS
Applications: 1970/75 F100/350, 1976 F100/350 before serial number A25,001.
---------------------------------------------------------------------------- D3TZ-15A404-B .. Wiring Harness-Clearance Lamps to Switch / Obsolete / 2 available NOS
Applications: 1973/75 F100/350, 1976 F100/350 before serial number A25,001.
---------------------------------------------------------------------------- D6TZ-15A404-A .. Wiring Harness-Clearance Lamps to Switch / Obsolete / 1 available NOS
Applications: 1976 F100/350 from serial number A25,001.
------------------------------------------------------- D7TZ-15A404-A .. Wiring Harness-Clearance Lamps to Switch / Obsolete / 1 available NOS
Applications: 1977/79 F100/350.
------------------------------- EOTZ-15442-E (replaced: EOTZ-15442 A & D, D6TZ-15442-A) .. Clearance Lamp Assy / Amber / rectangularshaped / one piece body & lens, less mounting gasket and socket / Available from Ford.
Applications: 1976 F100/350 from serial number A25,001 / 1977/96 F100/350, F(Super Duty) / 1997 F250/350, F(Super Duty).
MSRP each: $34.88 // FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price each: $23.02.
DOTZ-15442-A .. Clearance Lamp Assy / Amber / Tear Drop shaped / roof mounted / Obsolete / 85 available NOS
DOTZ-15464-A .. Clearance Lamp Lens / Amber /Tear Drop shaped / roof mounted /Use with DOTZ-15442-A only / Obsolete / 72 available NOS
---------------------------------------------------------------------------- EOTZ-15442-E (replaced: EOTZ-15442 A & D, D6TZ-15442-A) .. Clearance Lamp Assy / Amber / rectangularshaped / one piece body & lens, less mounting gasket and socket / Available from Ford.
My '76 F-350 has factory installed roof clearance lights, however they are the less common separate lens type. I was at the junkyard and was looking at the lights because I need the lenses and all the ones I saw from the '80-'86 & '87-'91 trucks had the plastic all in one style, even the '78-'79s I saw. I saw no '73-'76 with the lights, so the search continues.
