help!
Old Jun 19, 2012 | 08:11 PM
Dixieland Rebel's Avatar
Dixieland Rebel
help!
I am in process of a head gasket job, I can't remember which bolt holes to put the engine hoist points that are bolted the the intake manifold. Could someone please hep me, or take the air breather off and post a pic of the intake manifold as it sits. My truck is a 7.3 id istock motor
Old Jun 19, 2012 | 11:16 PM
84-6.9L's Avatar
84-6.9L
I think it was the right rear intake port and the left front intake port.
Old Jun 19, 2012 | 11:48 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
isn't one also the bottom bolt for the fuel water separator brace which is directly behind the top radiator hose on the pass. side front two manifold bolts?
Old Jun 19, 2012 | 11:50 PM
akamacgyver
Clueless spectator!
isn't one also the bottom bolt for the fuel water separator brace which is directly behind the top radiator hose on the pass. side front two manifold bolts? Which would agree with 84-6.9L
Old Jun 20, 2012 | 03:26 PM
Dixieland Rebel
Thanks, that was helpful info. Now for a second question, if I took the IP off with the gear attached what's the best way to get it back aligned? Do I have to take everything offf the front of the motor down to timing cover? Or can I , without damage, just move he gear tooth for tooth til its right?
Old Jun 20, 2012 | 04:06 PM
Dixieland Rebel
I have three brackets, two are just hoist points, One is a a hoist with a built in nut... the one with the built in nut I am trying to place correctly, I will just place the others diagonal from there. But it doesn't seem to be on the water separator brackets
Old Jun 20, 2012 | 05:05 PM
akamacgyver
Clueless spectator!
You did a bad, bad thing!
Dixieland,
I didn't know it either, but that is a major no-no on this motor. Fortunately for you, I have the solution. There are still some doubters, but the motor I did this to has been running flawlessly now for about 30k miles.
Give this post a read.
https://www.ford-trucks.com/forums/1...l#post11011403
Good luck,
Mac.
Old Jun 21, 2012 | 12:23 AM
akamacgyver
Clueless spectator!
Dixieland,
There is a brace that goes from the top of the water separator mount to the intake manifold. The engine hook you have with the mounting bolt on it goes here.
Name:  Pump install 007.jpg
The hook with the brace removed.
Name:  Pump install 010 - Copy.jpg
The hook with the brace installed.
Is that what yours looks like? maybe your PO removed the brace?!?
Hope this helps.
Old Jun 21, 2012 | 09:22 AM
Dixieland Rebel
Helps a lot!! I don't believe mine had the brace when I took it off, cause I don't have one with my parts, but this answers my questions completely
Old Jun 21, 2012 | 11:38 AM
akamacgyver
Clueless spectator!
You could probably fab something pretty easily. I personally would not delete any kind of structural item on these engines, it is probably there for a reason!
Old Jun 21, 2012 | 02:44 PM
Dixieland Rebel
That's what I had in mind, a thick piece of aluminum should do the trick nicely and should be day enough to drill bolt holes through
Old Jan 20, 2013 | 04:48 PM
Dixieland Rebel
head gasket job went south, i was told head gaskets, then cracked heads, then found a crack in the block upon further disassymbly. i have bought a rebuilt 7.3idi, with 26000 sine the rebuild. should be in within a few days.
Old Jan 20, 2013 | 05:28 PM
akamacgyver
Clueless spectator!
Same thing happened to me. I pulled my motor to do a HG repair, and both heads were cracked. I went through four sets to find two good ones to rebuild. 900 bucks later I had these.
Name:  New heads 011.JPG
About 5k since the top end rebuild, and she's running like a champ.
Good luck,
Mac.
Old Jan 20, 2013 | 06:23 PM
IDI guy's Avatar
IDI guy
Ok like Mac said it is a big no no but before you remove the housing you take the plate off of the front of the IP gear housing then take a straight edge and make two scribe marks, one on either side of the hole in the housing. Turn the crank until the small stud thing on the front of the gear is centered on the on the straight edge and take a picture of it. When you put it back on you just match it to the picture... unless you move the crankshaft then you have to do it Mac's way. I know it doesn't do you any good now but so you know for next time it saves you taking the timing cover off which is a PITA!
Old Jan 20, 2013 | 06:31 PM
IDI guy's Avatar
IDI guy
Originally Posted by akamacgyver
Dixieland,
Good luck,
Mac.
Good idea Mac I see how you got your name LOL. I just had to remove the timing cover on mine, what a pain! But I had to remove it beacuse i "f"ed up the gasket when I was removing the waterpump.
bryan_johnson
18
Mar 3, 2019 09:13 AM
badvad8486
May 23, 2018 07:48 PM
TxBrokenarrow
May 25, 2005 09:42 PM
Icicle
26
Jan 8, 2005 09:28 AM
