Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
rdubb
Old Jun 19, 2012 | 02:41 PM
rdubb's Avatar
rdubb
rdubb
I have a 1961 Ford 2 ton farm truck v-8 that I am rebuilding. I am putting points and condenser in now. I have been having a terrible time finding any information about this truck. What should the gap for the points be set on?
Old Jun 19, 2012 | 02:48 PM
85e150's Avatar
85e150
Try .017, that used to work for SBF and FE motors. Stand by for more.
Old Jun 19, 2012 | 03:47 PM
madrid london's Avatar
madrid london
use a match book cover!!! it has worked on Studebakers
Old Jun 20, 2012 | 08:12 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You might be better off checking the dwell angle, which should be somewhere around 27 degrees. Increase the gap on the points, decrease the dwell angle. Decrease the gap, increase the dwell angle.
Old Jun 21, 2012 | 04:39 PM
FBNengr's Avatar
FBNengr
Lightbulb
Chances are fairly good that the same distributor would have been used on other ford car and/or pickup engines of the same size and era. If so, almost guaranteed they would have had the same points, condensor, rotor, distributor cap, and points gap on all of them. Ignition timing could be slightly different between them though, and then again maybe not.
At any rate, should be a lot easier to find this ignition info. for cars or pickups than your 2 ton farm truck. Applying it to your farm truck should get you pretty darn close, if not right on the money.
Paul.
Old Jun 21, 2012 | 10:45 PM
85e150's Avatar
85e150
Asked and answered, I was close:
https://www.ford-trucks.com/forums/3...960-292-a.html
All the info:
tuneup.htm
hallgren87idi
Nov 24, 2013 11:22 AM
Baxtjh
Jul 7, 2010 08:19 AM
spiked
401, 477, & 534 SD Engines
Aug 2, 2006 02:11 PM
tx64f100tx
Feb 2, 2006 12:25 PM
72f100
May 23, 2001 06:00 PM
