Does a 2001 7.3 SD have a vacuum pump? If so, what is its' duty cycle?
I have a weird noise when I turn the key to the run no start position (sounds like a pump) which ends a few seconds later with a rattle. The unit this noise is coming from is on the passenger side fender under the hood, just in front of the blower motor. It doesn't sound healthy.
yes it has a vacuum pump. mine was making noise but not working right before it totally died. can you control your air flow in the cab? from the floor to defrost? if so its still working.
How extensive would it be to replace all the vacuum lines on a sd?? I've got one hanging that used to operate my hubs, my blower is slow to react and sometimes I'll get straight hot air out oft ac then cold conditioned air... Kinda makes me think there is a leak or broken line... Any ideas???? I don't want to just throw a part at it when the one there is working its just not hooked up completely
I've capped off line going to hubs and still have a vacuum leak. when I put my truck in 4wd my ac blows out of my defroster. Could it be my pvhs or is the leak in a line?
PVHS (or ESOF module) leaked - new one for about $75 at the stealership.
Cracked vac lines on the connector behind the wheel (turn the wheel to get at it without removing or jacking anything). I cut about 1 1/2 inches off the end of the vac tubing to the hub. Re-install freshly-trimmed end and have a celebratory beverage.
