79 Bronco smog help
Thermactor fresh air is plumbed to the cylinder heads where it is introduced just downstream of the exhaust valves. If your truck has a catalytic converter, it is also introduced into the OEM cat upstream of it. CA-equipped trucks were usually slightly different in the emissions configuration. Your best bet is to seek out the vacuum and thermactor plumbing diagrams for the truck. Chilton's often has this information in their manuals than Haynes but ideally a Ford manual would be helpful. It is also quite likely someone actually has more info than I can offer.
A new user just posted this photo of an 87 Thermactor air diverter valve (broken) in this thread that confirmed something I wasn't able to recall. Thermactor air injection and the plumbing to it includes this diverter as far back as the earliest EFI models and may have been present in late model carburated units as well.
<White Wolf>
11-15-2004 07:02 AM
Matthew Kindler
06-05-1999 03:55 AM
