1978 - 1996 Big Bronco
thermactor diverter valve
Old Mar 11, 2011 | 02:16 PM
gtgallo's Avatar
gtgallo
1979 351m CA Bronco. These valves are between the pump and engine to divert backfire. My D5ZE-EA valve has a hole in it. Found a junkyard replacement off another 79 truck D5ZE-CB . Would this be an ok swap.
Couldn't find any info. Anyone know?
Old Mar 12, 2011 | 01:25 AM
greystreak92's Avatar
greystreak92
The diverter valve alternates fresh air from the smog pump either into the heads or into the catalytic converter. The air injection pushes exhaust back through the EGR when the diverter is sending fresh air into the heads. When it is routing down to the cat., the fresh air is providing the needed oxygen to increase catalytic converter temperatures higher than combustion cycle temperatures. Frankly, I didn't even know 79's had them. They didn't change much if at all over the years... As long as it has the same vacuum and Thermactor hose connections as the original, it should function the same way.
Old Mar 12, 2011 | 10:52 AM
gtgallo's Avatar
gtgallo
Agree ,I'll give it a shot. These are obsolete parts. My original has a yellow band noting part number and the JU one has pink but matching hose connections.
Thanks
Tyaz92
Ford Truck Parts for Sale
Oct 10, 2014 05:38 PM
tatonka
Jan 21, 2014 06:14 PM
.Artisan.
Jan 23, 2011 11:55 PM
leftystar
Nov 7, 2007 07:09 AM
abelmoreno
15
Nov 3, 2007 06:59 PM
