what is this guys?
Old Jun 18, 2012 | 08:14 PM
Snuggyworm's Avatar
Snuggyworm
what is this guys?
hi guys,
i'm thinking this is the bump stop for the frame but i'm not too sure what this is. perhaps the gurus, techs and seasoned mechanics can chime in here and direct me.
what i need to know is what is it, what it does, what's the part number for the rubber donut itself, & how to replace it.
here are the pics.
thanks in advance fellas!
Old Jun 18, 2012 | 08:21 PM
2006powerstroke90's Avatar
2006powerstroke90
Body mount/cab mount which ever you prefer to call it.
Old Jun 18, 2012 | 08:22 PM
m-chan68's Avatar
m-chan68
That looks like the middle row cab to frame mount, on a crew cab truck. It is one of the eight cab fasteners that I remove, in order to separate the cab from the frame when I'm doing head gaskets on these. That appears to be one of the driver side cab mounts, since I see the parking brake cable beside it. To access it will require unbolting the driver seat, lifting up the carpet and removing the rubber grommet. You will need a 24mm socket to remove the bolt.
Old Jun 18, 2012 | 10:15 PM
Snuggyworm's Avatar
Snuggyworm
Wow. Sounds like work. Mike is right. I think I saw 8 of them. The second pic is at the rear of the cab n just before the flatbed.. the first pic is at the same level as second pic except on passenger side.
Do these things affect my ride? Comfort I mean. I find myself bouncing a fair bit. Could this be the problem?
Old Jun 18, 2012 | 10:24 PM
m-chan68's Avatar
m-chan68
On a Crew Cab, there will be eight cab to frame fasteners in total. On regular and extended cab bodies there are only six.
As far as your ride quality goes, I'd be looking at your shocks before looking at the cab mounts. To be honest, I have never heard of ever having to replace them before, at least I haven't myself.
Old Jun 19, 2012 | 07:06 AM
Snuggyworm's Avatar
Snuggyworm
Thanks Mike. I'm just concerned cos some of the rubber mounts are eaten away n I thought they look like they would dampen some of the vibration.
Old Jun 19, 2012 | 09:24 PM
dlibson's Avatar
dlibson
That's normal to see that rubber portion like that. Not gonna do a thing for you related to the ride if you replace them...
Old Jun 20, 2012 | 12:22 AM
Snuggyworm's Avatar
Snuggyworm
Good to know. Thanks so much.
66with352
Feb 28, 2018 02:33 PM
eb76adam
Jan 28, 2017 10:11 PM
Doc
20
Oct 7, 2011 03:06 PM
Farmall05
May 14, 2010 04:34 PM
hoof
Jan 17, 2007 04:03 PM
