Intake Plenum Removal.
Old Jul 8, 2012 | 09:23 AM
  #61
nossliw's Avatar
nossliw
That was the plan right before the hump hose. Hope it does not cause issues.
Old Jul 10, 2012 | 11:34 PM
  #62
nossliw's Avatar
nossliw
<style> <!-- /* Font Definitions */ @font-face {font-family:"MS 明朝"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:128; mso-generic-font-family:roman; mso-font-formatther; mso-font-pitch:fixed; mso-font-signature:1 134676480 16 0 131072 0;} @font-face {font-family:"MS 明朝"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:128; mso-generic-font-family:roman; mso-font-formatther; mso-font-pitch:fixed; mso-font-signature:1 134676480 16 0 131072 0;} @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; mso-pagination:widow-orphan; font-size:12.0pt; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"MS 明朝"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:JA;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"MS 明朝"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:JA;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} --> </style> Well here are a few more quick pictures of the piping finished. Thought I was all done and totally spaced on welding in the vent tube for the MAP line. Going to do that tomorrow night since I cant drive it anyways untill the box from Clay shows with that one additional boot I need and the new turbo intake boot...
So this is it for tonight.. The welding took maybe 10 minutes and the cleanup and paint maybe an hour or so... Fitment was the most time consuming part.
Almost there I just want to get it on the road again and will wait till winter for a Terminator and 1.5 sticks...
Hopefully in a couple of weeks I can get the water/meth injection on there.
Old Jul 11, 2012 | 07:10 AM
  #63
DIYMechanic's Avatar
DIYMechanic
Those pipes look great!
Old Jul 11, 2012 | 09:03 AM
  #64
nossliw's Avatar
nossliw
Thanks...
Looking forward to getting my third boot in tonight so I can finish it up and drive it to work tomorrow. I wish I had a second boost gauge just to see what the PSI drop is from the turbo to y pipe. Heard its about 2 pounds or so but I'm guessing it will be a bit more with the larger plenums.
Now to start finishing up the water injection parts list
Ill take a picture this evening of it all finished up. I just need to tack in the map line and weld the Filter intake tube shut to get rid of the CCV. Already rerouted it to a catch can.
Old Jul 12, 2012 | 08:00 AM
  #65
nossliw's Avatar
nossliw
Well additional complications arose and I posted them over here....
https://www.ford-trucks.com/forums/1...l#post12050231
I will get the final pictures posted up tonight....
On another note for some reason my EGT guage is not working at all... So I get to figure out what happened there.... I can only guess it was due to wiring the leads off the gauges together for power(not the thermocouple leads) or some how I have the thermocouple leads flip flopped...dang thing worked just fine before I started and that was one of my main priorities I had (see how my EGTs dropped) I still have to drill the manifold for the second one, but its wired.
Old Jul 16, 2012 | 10:37 AM
  #66
nossliw's Avatar
nossliw
Well from another thread I started regarding boost number on a stock tune, I was informed to move my map sensor line to the hot side. was told to trymoving it to the turbo side (hot). Turns out this did make a difference and I understand why (Or my theory tells me so). Our computer thinks (has been programmed) for a reading directly off boost directly feeding into the plenums. There was not a consideration for IC's, but by putting the <ACRONYM title="Manifold Absolute Pressure - MAP Sensor">map</ACRONYM> sensor line on the cold side you are going to read a pressure 1-3 <ACRONYM title="lbs per sq inch">psi</ACRONYM> lower than the hot side reading. Now your motor is seeing this pressure however the air is cooler/denser therefore requiring or having the capability to accept more fuel.
Having your <ACRONYM title="Manifold Absolute Pressure - MAP Sensor">map</ACRONYM> read from the hot side your computer sees 1-3 <ACRONYM title="lbs per sq inch">psi</ACRONYM> higher than your motor is actually seeing, however it is properly fueling for this volume or flow rate of air since you are gaining density but loosing pressure from the turbo to the head... I guess I look at it as a trick to gain a bit more fuel and actually saw a boost gain of about 2 <ACRONYM title="lbs per sq inch">psi</ACRONYM>. My gauge is at the Y and could consistently hit 15psi on stock tunes. Once I moved my <ACRONYM title="Manifold Absolute Pressure - MAP Sensor">Map</ACRONYM> I could hit 17psi on stock tunes. Once again this is reading on the cold side. If you were reading on the hot side it would be right around 20 for me pre cooler. Hopefully when I get my chip and stage 1.5's ironed out 30 <ACRONYM title="lbs per sq inch">psi</ACRONYM> will be an option post cooler.
Anyways I wanted to add that little tidbit of info. And if anyone disagrees I would like to hear your reasoning behind it. I do not think I'm always right but this seemed ligical to me
I will get some final pictures up tonight of it all installed and put together. Trying to find out a good place for the water injection nozzle...<!-- / message --><!-- sig -->
Old Jul 16, 2012 | 01:02 PM
  #67
fordpride's Avatar
fordpride
When I had my stageI's and my boost gauge hooked in the cold side I could hit 35psi
Old Jul 18, 2012 | 08:46 PM
  #68
nossliw's Avatar
nossliw
Well it rained here and I finally got a few photos of it all finished up... The setup is working great! Took a few of both trucks since I don't even have a photo of the diesel..
Old Jul 18, 2012 | 08:49 PM
  #69
ReBilld's Avatar
ReBilld
Wow! Nice job, it looks great! Nice trucks too!
Old Jul 18, 2012 | 08:50 PM
  #70
427 fordman's Avatar
427 fordman
Trucks look real good!
Old Jul 19, 2012 | 06:52 AM
  #71
DIYMechanic
Looks great! And the trucks look nice too!
Old Jul 19, 2012 | 10:41 AM
  #72
nossliw's Avatar
nossliw
Thanks guys I just wanted to rap this thread up with complete pics. I search so many times for stuff and you find a thread with exactly what you were looking for except the end result. So hopefully this might help someone out down the road if they are interested in doing the same thing... I know most just go to a different turbo at this point but I'm happy with this one
Old Feb 28, 2013 | 08:27 AM
  #73
nossliw's Avatar
nossliw
After going back and looking at this thread why did all the text get screwed up??? I was asked by another member to explain what was supposed to be there...looks like the html version is jacked up...pretty weird
Old Feb 28, 2013 | 10:06 AM
  #74
FI460's Avatar
FI460
My transmission swap thread did the same thing. Not sure on the reason.
I hadn't seen those pictures. Sweet looking trucks you got there
Old Feb 28, 2013 | 12:24 PM
  #75
DIYMechanic
Yeah somehow I missed the photos too. Nice looking trucks you have there. Who makes the bumper on the CCSB? I haven't seen one like that before that I can recall. I like it!
