390 to 351w swap
Jun 17, 2012 | 10:52 PM
Certified Thread Hijacker
It was directed at the OP. However, 8 mpg for a regular or mild 390 is pretty low.
I could easily get 12+ in my dual quad 428 on the highway. Commuting back and forth to work was around 10-11 mpg.
Josh
Jun 17, 2012 | 11:33 PM
So would it be worth while to just rebuild the 390
Jun 17, 2012 | 11:42 PM
To do the swap you'll need:
351 Engine
Transmission
Engine perches
Mounts
All accessory brackets
Possible Front and Rear driveshafts
Exhaust
It isn't as simple as yanking the FE and throwing in the Windsor.
Josh
Jun 17, 2012 | 11:53 PM
Quote:
Originally Posted by
Bullitt390
351 Engine
Transmission
Engine perches
Mounts
Exhaust
Josh
Ya I figured it would take a lot of work. My question is. Would it be worth that trouble or would it be worth rebuilding the 390?
Jun 18, 2012 | 12:07 AM
Lil Red Sled
I'm biased. I bleed FE engines, but I drink diesel.
Josh
P.S. That reminds me I need to do something about this 2.9 gasser in my Ranger...
Jun 18, 2012 | 12:10 AM
montana_highboy
A diesel swap would be my recommendation for any vast improvement in mpg's.
Diesel swap! 6.9 or 7.3 idi needs to go in there!
Jun 18, 2012 | 12:25 AM
I'd do a diesel but it would be a lot more work and alot more money!
Jun 18, 2012 | 08:27 AM
Bullitt390
351 Engine
Transmission
Engine perches
Mounts
Exhaust
Josh
dont know about the support stands. research indicates the 67-79 302 uses the same supports as the 77-79 351M/400. (Thanks Bill ) Should be a mount swap. agreed on the rest of the pieces. What about an adapter to run a 4R70 or 4R100 behind the FE???
Jun 18, 2012 | 09:01 AM
fitzwell
FE/I6
Small block
335/385
Josh
Jun 18, 2012 | 01:06 PM
Do they make adapters to put a zf5 on a 390?
Jun 18, 2012 | 01:32 PM
Lil Red Sled
Easier to adapt an NV4500
Josh
Jun 18, 2012 | 02:14 PM
Bullitt390
Josh
Ya I was reading on that earlier this mornin
Nov 13, 2012 | 01:10 PM
Ok. Which motor has more horsepower off the showroom floor between the 390 and 351w in truck bodies only?
76250highboy
Feb 1, 2005 01:51 PM
motolust
Engine Swaps
Aug 3, 2004 12:01 PM
2wheelpeel
Jul 15, 2003 07:52 AM
lostbuckeye
Feb 19, 2003 07:15 AM
GMFDBob
May 13, 2002 12:06 AM
