Engine swap goes wrong Help!
Old Jun 17, 2012 | 06:50 PM
Mythsearcher's Avatar
Mythsearcher
Ok I bought a 1986 with a spun rod bearing. I bought a Ho 302 from 1990 lx mustang.
I pulled the truck engine put all the truck stuff on the car engine. but i used the car engines fuel injectors,(but i checked they are the same part number,(I broke one figured i would use the ones with less miles)
Ok here is the deal its all together and i have 40 psi rail pressure and i have injector pulse . but it won't start
I shot some parts cleaner in the plenum and it will run on it...
Any ideas?
what's the chances of all 8 injectors going bad or getting stuck from sitting for 8 years?
Old Jun 17, 2012 | 07:12 PM
Anafiel's Avatar
Anafiel
Any ideas?
If you're not sure of those injectors, rebuild them with these kits.
RJM Injection Tech — Fuel Injector Service Kit
Here is the main link for RJM
RJM Injection Tech — Welcome
And EVERYONE should have a bookmark for this site:
Fuel Injection Technical Library
Old Jun 17, 2012 | 07:21 PM
Mythsearcher
thx that should help, the part i broke on the truck injectors is in the kit.
Old Jun 17, 2012 | 07:35 PM
1983F1503004x4's Avatar
1983F1503004x4
Bear in mind that a car 302 and a truck 302 are two different things. The car motor will lack the torque that may be present in the truck motor.
If you can, I'd just splurge and get new injectors.
Old Jun 17, 2012 | 07:43 PM
Anafiel's Avatar
Anafiel
Did you get codes? Also, I'm not sure the build on that mustang engine is the same that the truck's computer is expecting.
Little over my head here on this one. I can deal with EFI in my Bronco because everything is original (by part number) and the computer is getting the input it expects.
Old Jun 17, 2012 | 07:46 PM
Stangrcr1's Avatar
Stangrcr1
Interesting thought. Maybe it needs the stang computer? Did sensor locations change? Different sensor type?
Old Jun 17, 2012 | 08:01 PM
82f100460's Avatar
82f100460
I would certainly think so. certainly a different cam profile, rest of the engine is probably the same, or very similar. May have different emissions equipment as well.
Pull the codes and it will tell you why it's confused.
Old Jun 17, 2012 | 08:49 PM
Mythsearcher
I used every thing off the truck engine and it bolted right up. and plugged right in,
I even kept all the emission stuff. (I know but i may have to move back to missouri)
I do know it runs ok on starting(I mean brake clean its easier on the engine not as flammable as starting fluid. starts right up , its just not getting any fuel.
I do know the cam is wired like a 351w firing order.
I did run a scanner on it. code was for the pip(I think i think its the module in the distributor? I had it checked and is good) and the egr is out of range.
I got a good deal on a ford reman engine with low miles (he put a stroker crate motor in his mustang. he gave $1500 for the reman engine and sold it to me for $400.
Please Cut me a little slack I am a EFI noob. and new to the forum...
Old Jun 17, 2012 | 08:53 PM
Franklin2's Avatar
Franklin2
I would pursue the PIP problem. If you are not getting any signals from the dist to the computer, the computer will think the engine is not turning, and will not fire the injectors. The only way the computer knows the rpm of the engine, and where it's at in it's cycle, is the pulse signals from the distributor.
Old Jun 17, 2012 | 09:09 PM
Stangrcr1's Avatar
Stangrcr1
Yup. PIP. The PIP is not part of the module. It is the pickup in the distributor.
Read this
Mythsearcher
Not sure how would i check?
I used a noid light probe to check the pulse just plug it in and tried to start it
it flashes.I may try putting the drivers side fuel injectors.( the old ones) and see if it fires on 4
Old Jun 17, 2012 | 09:12 PM
Mythsearcher
Read this
Thx ill check that next i went ahead and pulled the distributor to get the module out.
Old Jun 17, 2012 | 09:17 PM
Mythsearcher
Nice looking truck.
I use to live in jasper and atlanta Ga.
Old Jun 18, 2012 | 07:11 AM
Conanski's Avatar
Conanski
The PIP module is your problem. Did you use the truck distributor or the Mustang version? Be aware that the HO has a billet steel roller cam in it and therefore requires a distributor with a steel drive gear, so using the mustang distributor would be best but you could also use your truck distributor if you changed the drive gear.
Old Jun 18, 2012 | 09:22 AM
Mythsearcher
They both had the same type gear
The car distributor was damaged , but I removed the gear and used it to prime the oil system with a drill before I started it
