Engine swap goes wrong Help!
Old Jun 18, 2012 | 08:26 PM
  #31
Franklin2's Avatar
Franklin2
Originally Posted by 82f100460
I've never working on one of the EFI truck engines...but is it possible to remove one of the injectors and see if will fire (pulse) quickly?
Not really. The Ford dealer has a tester they can use to test them individually, but the fuel rail holds them in place as well as feeds them fuel, so it would be hard to see if they are spraying. You probably could put a stethoscope on them and hear them clicking.
Old Jun 18, 2012 | 08:34 PM
  #32
82f100460's Avatar
82f100460
I would imagine that the firing happes so rapidly that you would not see any fluctuations in rail pressure either if you had a gage on there? You would probably have to have a very sensitive pressure transducer and track it on a chart recorder
Trying to think of a way to see if they're firing or not, or if they are just firing at the wrong time.
Old Jun 18, 2012 | 11:03 PM
  #33
Mythsearcher's Avatar
Mythsearcher
THANKS EVERYONE IT RUNS!!!!!
It was the PIP i changed the distriutor and roughly put it back in. It stared right up .
I have to set the timing (its not even close) runs ruff but at least it runs...
Thanks for your comments! Mythsearcher
Old Jun 18, 2012 | 11:12 PM
  #34
ctubutis's Avatar
ctubutis
Cool!
I just spent several weeks dealing with the distributor on my 1986 Tempo with TBI and EEC IV. Looks like the distributor just needs to be stabbed in the general area of where it belongs, the computer handles it all (assuming you've got the plug in that yellow/green wire down by the electrical connector at the dizzy).
I also figured out these PIP sensors are not all the same.
Anyhow, I'm glad you've reached a milestone.
Old Jun 18, 2012 | 11:15 PM
  #35
Anafiel's Avatar
Anafiel
Lesson learned.
pull codes...work the codes...truck runs.
Congrats!
Old Jun 19, 2012 | 12:24 AM
  #36
Mythsearcher
Originally Posted by Anafiel
Lesson learned.
Congrats!
Thats true but i would not have gotten it yet, if some one had not said that the module is not the pip....lol
Oh well working on the positive grounded points cars are roghting my brain...lmao
Thanks!
Old Jun 19, 2012 | 01:12 AM
  #37
Anafiel's Avatar
Anafiel
Thanks!
I know what you mean. These guys have saved my butt more than once. My trucks run good, and it's because of the tips and tricks I learned here.
Even the best of us (which ain't me) can learn a new trick every now and then.
Old Jun 19, 2012 | 05:29 PM
  #38
Franklin2's Avatar
Franklin2
Since you are new to this EFI game, I am not sure you know this, but to set the timing on these things, you have to take control away from the computer. You do this by pulling the jumper plug out of the SPOUT connector. If you follow the bundle of wires leaving the dist, one of them will separate out by itself, and it will have some sort of connector in it. You get the engine warmed up, turn it off, set your timing light up on #1 like you would do on a older engine, and take the SPOUT jumper out. Then start it up and set the timing to the the sticker on the radiator or the valve cover. Before you do that you might want to crawl under the truck and take some white out and mark the balancer in the correct spot. You might have to bump the engine over, but I find underneath is the best place to white out the balancer so you can easily see it from above.
After you are all done, don't forget to plug the spout back in. You will get a error code if you leave it out, and no timing control. What I have also noticed with these things is you have to drive them some before they sort themselves out. After about 3 days of driving it off and on, you will notice it will run different, as the computer learns and adjusts itself.
Old Jun 19, 2012 | 06:59 PM
  #39
Stangrcr1's Avatar
Stangrcr1
Thanks!
That was me back in post #10. Glad you got her running.
How about some pics?
Old Jun 19, 2012 | 07:04 PM
  #40
Anafiel's Avatar
Anafiel
How it works with my Bronco is, after any kind of work on it, I clear all codes. I usually disconnect the positive battery cable for like 30 minutes or so. Hook it back up, and take a nice drive around town. By the time I get home, the computer has relearned most of it's stuff. Gotta go through a couple of heat up/cool down cycles to nail it completely.
Old Jun 19, 2012 | 07:33 PM
  #41
Mythsearcher
Thanks for the timing tips
Also I'm working on my garage on the sight if anyone wants to see it while it's still kinda homely... But the engine is looking good.
I paint and stuff but beleave it or not I'm going to take it to a body shop and let someone else paint it.
All I would do is drive it like it is and never get it done.... Sad but my cars are the last ones to get worked on ... Lol
Old Jun 19, 2012 | 07:50 PM
  #42
82f100460's Avatar
82f100460
Nice....Glad to hear you got it all running. Seems I really need to do some reading up on these sytems myself....several terms I'm not familiar with.
PIP? SPOUT?
Old Jun 19, 2012 | 08:03 PM
  #43
ctubutis's Avatar
ctubutis
PIP? SPOUT?
Welcome to EFI.
oldfuelinjection.com (used to be called Ford Fuel Injection) is a great site to learn from. I am not at all ashamed to say I learned just about everything I know about EFI from people here on FTE - along with some web sites and a book recommended by Franklin2.
Old Jun 19, 2012 | 08:16 PM
  #44
Mythsearcher
Get a book... Lol... Ask my wife " he will mess with it for days before he will ask for help, or read a book" lol
And that's followed by typical man for yea... Lol
Old Jun 19, 2012 | 08:18 PM
  #45
82f100460's Avatar
82f100460
My ole' beater don't have EFI...but I like to learn
