Engine ID
Old May 7, 2003 | 10:12 AM
thinck's Avatar
thinck
Engine ID
I am new to Building Fords. I started with Camaros, then on to Jeeps, and now a 65 Ford Pickup. How do you identify Ford engines?
Old May 7, 2003 | 10:56 AM
William's Avatar
William
Engine ID
Welcome to FTE! V8 or 6? If V8 likely a 352. Post the numbers found on the intake and between the spark plugs on the head. After that look in the various engine forums for much more info.
Old May 7, 2003 | 11:12 AM
thinck's Avatar
thinck
Engine ID
Thank you. I will try to look on lunch. The guy I bought it from says the motor is actually from a 70's model. I know it is a V-8, 4-spd, with a 9" rear.
Old May 7, 2003 | 05:13 PM
Mike G's Avatar
Mike G
Engine ID
Welcome to the group as well! Another trick is to give us the count of bolts securing the valve covers.... There are a few others ideas in mind to assist us along, just keep trying, we'll get it!
--MG
Old May 8, 2003 | 07:02 AM
William's Avatar
William
Engine ID
You are well on your way, as long as it ain't a shivvey stuck in there.
Old May 8, 2003 | 10:37 AM
thinck's Avatar
thinck
Engine ID
Definately not a chevy. I originally actually bought it to use the 9" and the motor for a Jeep I am building but once I looked at the truck it just has so much potential
Nathan511
Jan 28, 2017 12:36 PM
Amish Ford
Jul 30, 2016 04:03 PM
Try this Ford
New Member Introductions
Feb 12, 2016 04:16 PM
Lead Head
2015 - 2020 F150
Jan 29, 2016 10:41 AM
62Cole
Apr 11, 2006 10:56 PM
