Update....i just got back from the hospital ....my wife required surgery and was thete for 5 days....so none the less the gears will be changed this coming weekend ...oh and my wife is going to make a full recovery
Glad to hear the wife will be ok, hope it was nothing too serious.
installation completed, 60 mph drops from 2500 rpm to 1650. But because of the larger pinion, a sensor is eliminated that I believe controls the rear abs and has something to do with the cruise control. Has anyone address this or have you just delete this? Thanks
Hey whip...i have been trying to contact you through private message but its not going through for some reason...is there any way i can contact you privately?
you will need a reflash so you have the correct speedo readings
No reflash needed, changing the gears dosen't change the speedo.
You may have a problem on the F450 rearend going to the 3;73 gears because the tone ring won't aline with the pickup sensor. I ran into this and installed a sprocket and pickup sensor on the output shaft behind trans.
