Sponsored by: Real Truck
AC issues
Old Jun 16, 2012 | 07:11 PM
sparkyd007's Avatar
sparkyd007
AC issues
Ok, so my ac is not working correctly. It is blowing around 108 degrees.
I assumed that it was just low on freon. I was incorrect. On the low side I am having pressures around 70!!! I noticed that the clutch is engaged all the time. Any ideas on where to look would be great!
Old Jun 16, 2012 | 08:19 PM
Pikachu's Avatar
Pikachu
What's the high side pressure? What's the ambient air temp?
Old Jun 16, 2012 | 08:21 PM
Pikachu's Avatar
Pikachu
Oh, and what year/model truck?
Old Jun 16, 2012 | 09:15 PM
sparkyd007's Avatar
sparkyd007
its a 2003 f250 with a 5.4.
I dont have a gauge for the high side.
And it is 23 degrees celcius outside
Old Jun 16, 2012 | 10:12 PM
Pikachu's Avatar
Pikachu
And you're certain the compressor is running? If you feel the refrigerant lines going to the evaporator in the dash board, are they cold? If so, I believe that truck uses a blend door to control the balance between heat and a/c. That could be malfunctioning.
Old Jun 17, 2012 | 09:42 AM
projectSHO89's Avatar
projectSHO89
Pop over the the HVAC section and see the FAQs. There is information there to get you started.
rblank
6.2L V8
May 18, 2017 10:18 AM
mizzleman
Jul 13, 2015 04:07 PM
0gers
30
Oct 5, 2011 04:05 PM
VA250SD
Aug 9, 2011 12:08 PM
GMAESTRI
1997 - 2003 F150
May 22, 2010 08:41 AM
