Dead brake lights and weird wiring
Old Jun 16, 2012 | 03:11 PM
mrc59's Avatar
mrc59
My dump trailer brake lights and turn signals suddenly stopped working after seven years. The running lights and electric brakes work fine.
I tow with a 2004 F-350. All the lights on the truck work properly.
I'm trying to figure out how to fix this. According to the diagram on the truck connection, facing the back of the truck, and starting at 12 o’clock, the six outboard connections are supposed to be:
#1 12v+
#2 RH turn/stop
#3 electric break
#4 ground
#5 LH turn/stop
#6 running lights
and the center #7 is the backup circuit.
But when I put a volt meter on the connections and get the wife to help, I find that #1 is the running lights, #4 is the constant 12v, and #5 is ground. The other pins remain dead.
So, I have these questions:
1) Do the connections marked on the socket tend to be different?
2) How can I have decent electric brakes, yet find no voltage on the other pins when the wife hits the brake pedal and maxes the controller switch?
3) Where should I first check for the dead brake light/turn signal wires?
Thanks so much!
Old Jun 16, 2012 | 08:48 PM
RV_Tech's Avatar
RV_Tech
#1 12v+
#2 RH turn/stop
#3 electric break
#4 ground
#5 LH turn/stop
#6 running lights
Thanks so much!
The connections do not differ. check the fuses on your truck for these functions. If they are all good, consider the connections at your seven pin.
Steve
Old Jun 18, 2012 | 03:57 AM
Loveland's Avatar
Loveland
brake lights and turn signals dead
I am having the same issue with my 2008 F-250. It has a factory tow package, and i just re-wired the truck plug. I have no voltage on the tow pins that should turn on the signals and brake lights. Just curious if you found a fix for your truck.
Nathan Loveland
Old Jun 22, 2012 | 07:31 AM
mrc59's Avatar
mrc59
Haven't had a chance to check fuses yet. Hope to today. I didn't do any re-wiring.
Old Jun 22, 2012 | 08:20 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Checkout my thread on a 7 pin plug https://www.ford-trucks.com/forums/1...-cord-end.html the same thing was happening to our trailer.
Denny
hasteranger
May 24, 2016 02:21 AM
sleep_deprived129
Mar 17, 2009 01:38 AM
f350ford17
Dec 26, 2008 05:25 PM
64f250guy
Nov 27, 2003 08:37 PM
coop90
Jan 7, 2002 09:50 AM
