Injector time? Yes and more PMS.....
#31
#32
So yea, little tiny bubbles in the water. Took a bit for them to show up but what does it mean? Leaking head gasket pushing air into the coolant?
#33
i find that some cars after sevicing the cooling system need to be blead thoroughly and will still have small bubbles but they are the ones with caps on the radiator so when doing a final check over and taking the cap off the pressure will always push enough water out to create a air gap thus causing bubbles to start appearing. but a enclosed system soto speak with a reservior bottle the engine and radiator, providing the bottle water level is above the main feed hose and is the highest point of the system it should be totally free of air. i think before jumping to a headgasket conclusion keep and eye on the temp and if the top hose after a run looks like it is expanding a little or you are unable to squeeze it a little. maybe borrow a cylinder pressure tester off someone and check each cylinder is holding pressure while you have the glow plugs out. but bubbles are a first visual sign for me to investigate further.. even the smell of coolant while driving could be a sign that it is being pumped out due to over pressure.
#34
actually i think there is a small hose that runs to the top of the bottle from the top of the radiator you might have to temporaraly fill the bottle right up and watch to see what happens. the water will rise in the bottle as it heats up and over flow but after sitting there idling for 10 min or so and up to temp if the bubbles are still there look further. if its all good the water will find its own level after you replace the cap and have done a few miles..
#37
My wife and I have fun naming anything with wheels or transportation related.
- I don't know if they call Harleys "hogs" in Austrailia, but they do in the US. With that in mind, we bought a scooter at the Harley dealership and named it "Piglet"
- We have a utility trailer and named it "Flatso"
- The boat trailer is "Doc"
- The battery-powered lawn mower is "Buzz"
- Diesel is notorious for being odoriferous, so "Stinky" popped up in about 2.5 seconds and it stuck.
#38
the harley scooter name is gold LOL. my mates kids have thoes little pit bike chopper looking bikes, i might throw that name at them and see if it sticks..
your pet names are all great the girlfriend had a laugh after relaying them to her haha..
yeah well you are right stinky is apropriate for them especially with a ccv delete, i need a catch can with a filter on mine i find smoke rising from under the tub when im at the lights. get some funny looks, but id rather that than oil in my new/clean intercooler.
cheers
josh
#39
#40
OK. So I started it up today again and when it is cold the miss is noticable but the low end power is good. Once the truck warms up the low end power goes to crap and the miss is VERY noticeable.
I even changed the CPS and it didn't help.
Here are a couple videos to hopefully relay what I'm talking about...
2012 06 22 15 05 48 756 - YouTube
2012 06 22 15 08 51 549 - YouTube
#41
My concern is if it is something else I don't want to be left stranded with a 8K lbs truck that won't move and it doesn't act like it has air in the HPOP, it acts like a injector isn't firing worth a crap once it gets hot.
#42
#43
i have had cars that seem fine in the shop then when test driving, i dont know if its because load is put on the engine or what but the head gasket will start to leak and pump the water out. then back in the shop it seem to dissapear...the water in the bottle didnt seem to bad with bubbbling but it was hard to see....
#44
#45
huh. Almost looked like I was being pissy in my last post. Sorry if it came across that way. Wasn't trying.
None the less thanks for all the help. I'll keep this thread posted as I continue to troubleshoot and narrow down where the problem may be.
I plan to conduct a coolant pressure test and compression test as soon as I can afford to.
Thanks for all the help guys, I'll let you know what I find.
