Fuse keeps blowing...??
Old Jun 15, 2012 | 07:51 PM
Lakvoodoo's Avatar
Lakvoodoo
Trailering
I've got a 6.0 PS Diesel which for the most part I've taken immaculate care of. That said, I think I might've knocked something loose offroad a few weeks ago. Since then, FUSE #27 (15amp) which is the "Ignition Switch Run feed", keeps blowing. I'll switch it out and everything works fine but only for about 5-7 starts, then it blows out again.
You guys have any suggestions? While I can easily keep switching out the fuses, this is only a 'bandaid' for something bigger that's wrong, plus I dont want an even bigger problem.
(Secondly, it says it should only be a 15amp, but what would happen if I put a 20amp? Just curious.) Thanks much!
Old Jun 15, 2012 | 11:03 PM
2006lariat's Avatar
2006lariat
Putting in a 20amp could overheat the wiring, and ultimately burn the truck. Look for something shorting out the system. (You said you were offroading, could there be a weed or stick that gets wet and is causing a random short?) Look for chafed wiring also.
Old Jun 15, 2012 | 11:48 PM
Aune163rd's Avatar
Aune163rd
Wow....that is an electrical nightmare...ive heard that these 6.0l engines are way to electronically controlled....
Old Jun 18, 2012 | 08:49 PM
Lakvoodoo's Avatar
Lakvoodoo
Trailering
Thank you.
daveboley
Jul 12, 2019 05:50 PM
IamToyoftherm
2004 - 2008 F150
17
Sep 8, 2012 10:23 PM
Lakvoodoo
Jun 18, 2012 08:50 PM
PC6Flyer
Sep 24, 2009 07:18 AM
tjbeard
Electrical Systems/Wiring
Oct 22, 2005 04:23 PM
