Scanguage 2 mounts.
Old Jun 14, 2012 | 01:44 AM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
Scanguage 2 mounts.
I just recently got an Excursion so I just started posting on this forum, Im mainly on/from the 6.0 side with my 05 F250 and I came across a post on here the other day about the scanguage 2. I have one in my 6.0 and I had made a dash mount for it that several from the 6.0 board commented on and so I made more and sold out. I have since made about a dozen more and since there are Ex users using the scanguage I thought I would mention it to you guys. Here are a couple of pics. They are made from a plastic type material that we use at work to make patterns and core boxes for our foundry. It is called renshape redboard and is very durable. I paint them black since the material is red. Now keep in mind that I have them made to use the rear jack on the guage and the mount is secured to the dash via 2 screws. I drilled a hole to feed the cable through for a clean install since I didnt want any wires showing. Again I just thought I would mention them in case someone wanted to get away from the normal velcro way of mounting. If anyone is interested hit me up with a pm for details.
Old Jul 28, 2013 | 06:18 PM
2civicrr's Avatar
2civicrr
Sent you a message. Thanks
Old Jul 29, 2013 | 12:02 AM
Karlsgems's Avatar
Karlsgems
Mark,
Thanks for sharing this with us! (Reps sent!) Welcome to this forum, lotsa good people here. Love your screen name, btw.
Wondered if you have any pics of one mounted in an Excursion? The top of an Ex dash has contours different from your truck and I'm not sure how this would attach.
TIA,
Karl
Old Jul 29, 2013 | 01:39 AM
ROBBINthaHOOD
In the Ex I have it mounted on the flat area just under the headlight switch. I will have to take some photos of that and post.
Old Jul 29, 2013 | 11:40 PM
Karlsgems's Avatar
Karlsgems
That'd be great. Thanks bro! Looking forward to it.
Also had the thought that there is a flat edge just above the vents, but it would only accommodate screws at the bottom of the box you created. Not sure it'd work. Anyways, definitely post that up so we can see.
Karl
lottery_loser
Mar 17, 2016 05:36 PM
DSN46
Oct 22, 2013 06:25 PM
levimorris85
Oct 4, 2011 09:08 AM
ma115
Oct 22, 2010 11:36 AM
Kimo
Jun 1, 2008 10:14 PM
