I hadn't seen your video before. Did you really set your boost for 20 lbs?
No, those are just some test guages I have. My boost is set to 40psi, back pressure to 50psi, fuel pressure to 25psi, oil pressure to 20psi, water temp to 220, oil temp to 225, EGT to 1240*, Diff temp 230, tranny temp 220, volts to 11, and thats about all I can remember off the top of my head...LOL
I set my water temp at 210 for now. Boost at 27, trans temp at 215 and EGT at 1200. Boost and EGT are probably the only two I will ever see come on though.
Install ISSPRO Warning light software issues with Windows 7
Don’t know if it is just me or anyone with Windows 7.
I had an issue with CMD file that is used to install the software.
I had to open the Setup.cmd file and manually run each step.
FYI: Windows 7 does not always handle the wildcards like %cd% the same way XP does. I had to place my drive letter in the commands for my CD drive to get mine to load.
I replaced the “%cd%” with “e:\”
After a little install frustration I got my gauges programmed. Hope this can help someone else with Windows 7
I installed it on Windows 7 with no issues. One thing I learned is to never ever name your computer with an & symbol. Most people name them something like wife's name & husbands name. That will cause hate and discontent with many programs as the & symbol is a special symbol and some programs just get angry. You have to delete that profile and build a new one if that is an issue.
