Not a problem. I replaced my 10cm blocks with used OEM 5 cm blocks. Wanted a more level truck. With V code springs in front the rear is only an inch higher. I gave away the 10cm blocks or they would have been your's. Someone who has done a lift and has some 10cm blocks might chime in or you can start another thread asking if anyone has them.
Yea im going new on the u-bolts, not chancing that. Just found a guy out here that parts out fords so I gave him a call and he happend to have a set of the 4 inch ones that just came in on a truck that had the frame bent from a collision. Talked to him, he has no clue what there worth so im going to make out pretty good on those.
Sounds like a good deal. Measure one of the u-bolts or trace around it on a piece of cardboard so you know what to get. He should just gve you one of the u-bols. They're only worth their weight as scrap. Don't forget new flange nuts for the new u-bols.
Sounds like a good deal. Measure one of the u-bolts or trace around it on a piece of cardboard so you know what to get. He should just gve you one of the u-bols. They're only worth their weight as scrap. Don't forget new flange head nuts for the new u-bols.
SRW and DRW will have two different axle tube sizes I believe, so the ubolts will be different sizes.
The U-Bolts they all come sold seperately, so I should just be able to go to my local auto shop around here take one outside to see if its the same as the one on there, just 2 inches longer. Or at least thats my thinking, but my thinking just got me in trouble and I had to take back some autozone blocks that were to skinny. I need to quit thinking and leave that up to yall.
Good point Crewcab.
Does the parts truck and your truck have the same axle? If so then it is best to have a u-bolt with you when you buy. You want to make sure they are threaded far enough down to have enough thread to get them properly torqued.
Could not tell you. I have even yet to see the truck or anything he owns. I may make the drive out there tomorrow to get them. And ill be taking a little extra money in case he has something out there I should also/want to buy.
