sct tuner with stock head studs?
ahhh Bully Dog -- have a buddy with a Cummins that runs one. They don't tend to be friendly with our transmissions, but hey, it's only 3-5K to fix a Torqshift...
I plan on putting a Gearhead Performance SCT tuner to my truck when i get a chance, and my truck has stock bolts, but i really dont plan on using more then the 8k tow tune.
Between my buddy, his brother, and his dad, they have owned 7 6.0 powerstrokes. he is the one who convinced me to buy a powerstroke truck and it has run great stock. The only truck that ever gave them any trouble had a banks kit in it, the other 6 had only minor issues.
On the other hand, trucks that have strict maintenance still end up blowing bolts at 10,20,30-50k at stock power levels.
If you're going to tune on stock bolts, use SCT, invest some time in contacting companies about non-studded tunes.
on
From those that have heavy left foots, to those that let their trucks idle (that still have the EGR working (which I did even after all my mods and never had an issue with it)) for long periods of time. Adding more heat, fuel (and unburned sticky fuel at that) doesn't look good for the longevity of the truck.
Just because ou take it in for it's regular severe service maintenance doesn't mean that you aren't rough on it when driving it (either loaded or unloaded).
Unless you are getting a tune that detunes (considering your argument is that this can happen regardless of tuning or not, the best option is to detune the truck), you are adding even more heat, more stress to the truck, how does that not hurt longevity of the vehicle?
I should mention that this is coming from someone that had the following (not compressive, just the stress adders):
Spartan Tuning
Stage I injectors
64mm non-vgt turbo
I just wanted to make sure that you didn't think that this was coming from a stock only type of person.
To a point yes, but it mainly depends on how a driver handles that new found power. They better that they are with the demands that they place on that truck, the better their chances are not having issues.
Spartan Tuning
Stage I injectors
64mm non-vgt turbo
Spartan Tuning
Stage I injectors
64mm non-vgt turbo
Too rough in my opinion, is just skipping warm-ups. When the engine's hot, step on it freely with no issues.
Personally, i don't leave my drive way until the glowplug drain is gone, by then ect/eot is usually 80-90 dF.
I don't know what companies do between studded and non-studded tunes to keep it safe, but they're doing a good job at it. As long as they're used for what is stated right?
People who strap a performance street tune on and then tow 10k# are just asking for trouble, even studded drivers switch to tow tunes for a reason.
I guess it all comes down to sensibility like you said
on
I do as well, but only after the truck has gotten up to operating temp. I think that's the biggest difference as to what people do. Especially in the winter time when it might take 20 minutes of drive time (around here) to get it up to operating temp in the first place. For some, that's the entire drive.
That's pretty much not relevant to bolt life, it just depends on the truck. Some people run tunes, hot tunes and whatever on stock bolts with 200k on them and the truck doesn't skip a beat.
