Fuel Injectors
Old Jun 13, 2012 | 11:08 AM
rvicejr's Avatar
rvicejr
Fuel Injectors
My check engine light came on so I had it checked and was told the codes are saying that all of my fuel injectors are low. I was told they would not all go out at one time that it may be some type of relay or something that is causing it to show that.
Does anyone know what it may be or can help?
Thanks in advance!
Old Jun 13, 2012 | 11:09 AM
rvicejr's Avatar
rvicejr
By the way.....I have a 2006 Ford F-350 SRW 4x4 6.0
Old Jun 13, 2012 | 02:54 PM
FI460's Avatar
FI460
If it's a low voltage code I would bet your FICM is toast. When mine died all 8 injectors threw a low voltage code. If you go down to the 6.0l diesel forum there's a good write up on how to test your FICM in the tech folder and there's lots of good information on replacing them if you do a search.
Old Jun 13, 2012 | 11:05 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Jun 14, 2012 | 04:58 AM
npccpartsman's Avatar
npccpartsman
Thanks in advance!
I'd suspect the FICM has failed also and needs to be fixed before it starts taking out injectors. As stated, check the 6.0 tech folder for the proper test procedure and then send it to FICM Repair.com - Your Source for FICM Repair for a quality repair experience
DennisA (IL)
Dec 16, 2017 10:17 AM
pendukasafaris
Nov 29, 2013 01:12 AM
sassydog
Aug 9, 2008 09:13 PM
jn12170
Feb 25, 2008 10:00 PM
davedawe
1983 - 2012 Ranger & B-Series
Feb 2, 2005 06:25 AM
